Topic: Rane Four VDJ Support - Page: 6
Hi all. I've been waiting for a paid FLX10 since summer, and I'm fed up with Pioneer constantly changing the delivery dates. So, I'm considering switching my order to a Rane Four, which is always in stock.
Is this a good move?
Are Rane users around here happy with it when using it with Virtual DJ?
Is the integration with our beloved software "perfect"?
I'm steering clear of Serato and any other DJ software that isn't Virtual DJ, so I'm particularly interested in hearing your impressions on how they work together.
Are there ongoing corrections or was there an initial mapping, and no further work is being done?
I know things with Pioneer are easy, where, due to the large user base, Virtual is continually working on issues and improving with each early access but is it the same with the Rane Four?
Let me know what you think.
Cheers
Rane Four works "perfect" with VirtualDJ.
I have personally used it in 6 live gigs this summer without any issues at all.
The only advise I have for Rane Four users, is to set zerodb setting at -6 or even -9db.
Generally it's a very good controller, but it doesn't like redlining. If you hit red on the VU you're gonna hear it! :)
PS: Yes, it's loud enough and you don't need to push it on the reds
Thank you Phantom, good advise! ;-)
I know each one has strong and weak points but, do you personally prefer the Rane over the FLX10 if you would need to choose only one of them? Truly inclined on the Rane just now, but I'm afraid to take a wrong decision just for impatience.
I cannot tell.
I have not used the FLX10.
I can tell though, that Rane Four was the first controller that made me think to replace my own personal favorite controller for gigs, DDJ-RZ.
The main differencies I can see between Four and FLX10 are:
Four has a hardware mixer, while FLX10 has a software one.
Four has some nice built in hardware effects and you can switch (on the fly) to software effects as well. FLX10 only offers software effects
In Four you can't have automatic headphones switching (because of the hardware mixer) but on FLX10 you can
The pads display on Four is far supperior to that of FLX10 as the display is always there. In FLX10 you need to manually bring it up for a few moments
The pads on Four are very nice, but FLX10 pads are a little better.
Four has a sturdy metalic body. FLX10 is more plasticy, but the construction/finish is very good. This also means that FOUR is heavier than FLX10
Four uses a standard IEC C13 power cable. FLX10 uses an external PSU
For the rest of their differencies you can read their operating manuals
https://virtualdj.com/manuals/hardware/rane/four.html
https://virtualdj.com/manuals/hardware/pioneer/ddjflx10.html
Wow, really good and useful info. Very kind of you, George. I have made my choice ; )
I know this is a dated thread but that is something I was looking for on the Rane Four! I set mine to -9 db. Yes, its plenty loud. One other item I've encountered is the dedicated Flanger does not oscillate automatically like the Serato Pro does unless I use the hardware effects section. Is the knob under the channel a software effect?
You mean the color effects ? They are hardware.
Also VirtualDj passes the BPM of the deck on the unit. So, it should have no issue to handle it.
I will take a look at it tomorrow, but IIRC Flanger color effect works fine here.
Yes, the Color Effects is what I meant. I have to oscillate it by turning the knob, it won't work automatically.
Yes, the Color Effects is what I meant. I have to oscillate it by turning the knob, it won't work automatically. Serato's works automatically. Not that this is a big deal, I can oscillate by hand.
Does anyone know of a way to get Prelisten working with headphone audio on the Four? Seems it may not be possible due to the hardware mixer.
Yes, it's not possible, unless you're willing to loose one of 4 decks.
BTW: A new mapper update is coming to support control of stems with the EQ knobs (for devices with the latest firmware 1.7.0.8 or greater)
Thanks for the info! I assume this would be true for any controller with a hardware mixer?
[quote=PhantomDeejay]Rane Four works "perfect" with VirtualDJ.
I just want to clarify here so no one else makes the same mistake I did:
While pretty much every part of the Rane Four "works" with VDJ, I sadly had to return it as it lacks some pretty basic functionality due to the hardware mixer. It's a great mixer controller overall, but the mixer doesn't play nice with our software.
If headphones are connected to the controller, you cannot use the prelisten function. It will play audio on the deck channels instead of over the cue channel. Alternatively, you can set headphone or prelisten output to play from your PC, and connect headphones there, but then you lose the ability to hear EQ changes in cue. This, on top of the inability to hear hardware effects in cue when connected via either method, is a pretty big compromise.
I cannot tell.
iNTERESTING: I am still using my DDJ-RZ and have considered a Rane 4. DO you still feel good about the Rane 4?
hmmm. My ddj-rz works perfect and I can do everything that you jjust said the rane4 cant... Damn. Im really looking for a new controllers after all these years but I still have the best I guess.
I'm pretty sure this is the case for a fairly large portion of conrtollers you will look at - once the mixing is done in the hardware, VirtualDJ can only send audio to the channels available (if you look at the audio setup, the headphones/cue path is not part of those channels, so to achieve what you want, one of the actual channels for audio would have to be sacrificed, and all of them pretty much lead to master output). It is additionally unfortunate that the Rane Four doesn't seem to have a master output cue (which is probably what you need to hear the effect result after the send to/return from VirtualDJ is done).
The additional truth here is, this is probably exactly how the unit will function with Serato, and Serato does not have a prelisten function. That is why what @PhantomDeejay said is correct...it does work perfectly with VirtualDJ, because the experience is the same as what you would get if you used it with Serato when it comes to that.
To achieve what you want, you should look for controllers that let the software do the mixing...the DDJ-FLX10 and DDJ-1000 are 2 that come to mind(note the audio setup shows "Master" and "Headphones" channels explicitly, so VirtualDJ can actually control what is sent to the headphones/cue vs output to master explicitly there).
Edit: @PhantomDeejay already addressed this in detail earlier... just doubling down on his claim being true.
@Burnyabad:
I finally retired my DDJ-RZ about 2 or 3 months ago.
Nothing wrong with it. I just wanted to switch to something new. I'm doing less gigs than I used to do a few years ago, and since size was never an issue for me, I decided to go with Opus Quad for the moment.
However I still use Rane Four ocassionally.
Since both Opus and Four feature a hardware mixer, I DO miss the autoheadphones function. However I can live without it, as my 25 years of muscle memory makes it very easy to get used at pressing those PFL/CUE buttons again :P
The ONLY reason I didn't pick Four over Opus (after all it's smaller and lighter, but remember size was never an issue for me) is the LOCATION of the headphones controls on the Four (front panel) versus Opus (top panel)
For me, PERSONALLY, this is the only deal breaker at making Rane Four my favorite controller.
You see, I perform by using IEMs (In Ear Monitors) and therefore I need to change the HPMIX between "LIVE" and "PFL" all the time.
Rane Four does this, but I cannot get used to quickly and easily grab the knob and do the change on the damn front panel..
I know that this issue is meaningless for most people. Therefore I still DO recommend Rane Four as a nice controller for VirtualDJ.
The latest firmware update also solved some "minor issues" I had with it.
For instance now the MASTER VUmeter can be set to POST fader and therefore show the actual level you're feeding your amps. Before it would be PRE fader, making it almost useless for me.
Finally, you can control stems on all 4 decks now by using the EQ knobs.
So yeah, it's a nice controller. If the damn HPMIX knob was on the top panel, I would not have to carry the Opus around!
Hmm, fair point that the prelisten function died doesn't exist in Serato, I wasn't aware of that.
I suppose we have different definitions of what "works perfectly" means. To me it means all functionality provided by VDJ can be utilized by the hardware. (not sure that controller exists)
I did some more digging last night and I'm wondering if I could get the hardware effects and maybe even the EQ to be played over the "headphones" output (routed to pc headphone jack) by also routing deckfxreturn 1 to it. Unfortunately I already returned mine, perhaps a bit too hastily. Would someone here possibly be able to test this?
96%
