I have a request too if possible ;-)
A button like the one "SHOW FILES" (next to it, on the left) but with "SHOW COVERS" (view_options 'showcovers')
=> you can decrease the width of "AUDIO" / "VIDEO" / "KARAOKE" to have the space for it.
Posted Sat 26 Mar 11 @ 2:57 pm
Good idea. Will do.
Posted Sat 26 Mar 11 @ 3:35 pm
Update for X-Wide version
VirtualTouch X-Wide ver 1.1
Download Link
http://www.virtualdj.com/addons/12737/VirtualTouch_X-Wide.html
Ver 1.1
@Mark. It was quite hard to add PitchLock. You may use the OTHER panel where pitchlock is available as a multibutton.
Download Link
Ver 1.1
- Added Show Cover action
- Added Goto Folder Action
Posted Sat 26 Mar 11 @ 8:09 pm
is there anyway to download this with virtual home just for playing around with ?
Posted Mon 28 Mar 11 @ 12:44 pm
You will need at least the Broadcaster or the Basic Version to be able to download skins. Check here the Comparison Products Page
http://www.virtualdj.com/products/comparison.html
Posted Mon 28 Mar 11 @ 12:48 pm
good work with the skin.
but any chance of the updates done to the 1280x 1080 skin ??
Posted Wed 30 Mar 11 @ 5:55 pm
I've never seen such a resolution. It would be difficult. Skins with no browser, can not get resized in different ratio. The closest to your resolution is the VirtualTouch at 1280X1024
Posted Wed 30 Mar 11 @ 7:19 pm
Hi sorry yea. i made a mistake on that resolution..
just would like to see "Go to Folder" and Pitch Lock added to 1280x1024 please please please (",)
Posted Thu 31 Mar 11 @ 3:47 pm
Goto Folder will be added. PitchLock, you can add it as a Multibutton.
Posted Thu 31 Mar 11 @ 4:34 pm
Thank you.
Posted Sat 02 Apr 11 @ 10:08 pm
Update
VirtualTouch ver 1.1 1280X1024 (not the Wide one)
![](/image/72742/58892/VirtualTouchLogolarge.jpg)
Download link :
http://www.virtualdj.com/addons/12532/VirtualTouch.html
Ver 1.1
Download link :
Ver 1.1
- Added Show covers button
- Added Show Music, Video, Karaoke Files button
- Added Goto Folder button
Posted Sun 03 Apr 11 @ 6:02 pm
thankyou thankyou thankyou (",)
Posted Sun 03 Apr 11 @ 8:13 pm
I love the VirtualTouch Double skin.
Is it possible to do the doublescreen skin, as i single-monitor with screen-swap. Press a button, and the "decks-view" is showing, and press the buttion again and the "browser-view" is shown?
Or just the decks-view, with browser minimized, and press of a button the brower maximize?
I hope you understand how I thinking.
Posted Mon 04 Apr 11 @ 6:12 am
What you ask is VirtualTouch skin. http://www.virtualdj.com/addons/12532/VirtualTouch.html
Posted Mon 04 Apr 11 @ 6:46 am
Okey, f***in perfect. :-)
I´m going to try out that one.
Thanx
Thanx
Posted Mon 04 Apr 11 @ 6:55 am
virtualtouch 1.1 (not x-wide)
the cuepoint markers are not showing up on the decks panel.
Posted Tue 05 Apr 11 @ 6:18 am
I'll check this tonight mark. thanks.
I'm sure i missed something. I will upload an update tonight.
Sorry.
Sorry.
Posted Tue 05 Apr 11 @ 8:49 am
also, could we have the OTHER menu put on the 'not x-wide' decks skin??
Many thanks and brilliant work on the skin.
Posted Tue 05 Apr 11 @ 8:51 am
Update Fix
Ver 1.1.1
- Fixed Cue points on songpos and waveform
Download Link
Ver 1.1.1
Download Link
Posted Tue 05 Apr 11 @ 2:35 pm
Hi,
This is a Great Skin for a touch screen.
I do have 3 questions though:
1. On the browser view, when I press "Playlist" button nothing seems to happen. Should the playlist appear?
2, Is there a way of increasing the width of the scrollbars?
3. Is it possible to have "Mix Now" on the video view?
Thanks!
Keep up the great work!
Thanks!
Posted Tue 19 Apr 11 @ 5:27 pm
