groovindj wrote :
Why didn't you assign it to something on the XP2, as that's where you're controlling the sampler?
I wanted to map it on an unused knob on the mixer, but I was not able to do it...no unused knobs on the XP2
Posted Sat 18 Jan 25 @ 7:49 pm
That was your problem. There weren't any unused knobs on the mixer. It's hardware, so every knob and button does something. The XP2 is only a controller so any knob or button can be assigned to any function.
Posted Sat 18 Jan 25 @ 9:10 pm
Unused in sense I didn't need to use it for its original purpose. On XP2 just one very usefull knob...
Keyboard is fine.
Posted Sat 18 Jan 25 @ 9:49 pm
DJ Faber Zee wrote :
Keyboard is fine
....and a keyboard doesn't have any knobs at all. To me it makes far more sense to put all the sampler related functions on the hardware you're using for the sampler.
Just a suggestion.
Posted Sat 18 Jan 25 @ 10:27 pm
Just a suggestion.
Keyboard is fine
Just a suggestion.
I know...but Volume Sampler should be on the mixer in my opinion...but incredibly VDJ support refused to tell me how to map it...so keyboard was my preferred choice...Because yesterday when I tried the Club Setup + DDJ-XP2 I realized how different Samples volume sounds on that thus I need to control it in a easy way during a gig.
Posted Sun 19 Jan 25 @ 4:56 am
Not sure what you mean by refused. This topic explained several times that you could use a different knob that you don't use as long as
-the hardware functionality of the knob isn't used either (so the balance knob is probably out for that reason)
-the knob actually sends midi (so some of the mic knobs are out for that reason)
Posted Sun 19 Jan 25 @ 5:43 am
I was expecting by VDJ Official Support a detailed guide on how to map it, but they told me is out of scope because is personalization and not a bug or a SW issue.
Yesterday I finally had the chance to try (I do not own a DJM900NXS2) at the club, but I wasn't able to find anything related to the two knobs I would have wanted to map, then I decided to use keyboard.
If someone would be so gentle to tell me how exactly I can map it, it would be appreciated...
Which is the key I need to choose in order to map one of the two highlighted knobs on DJM-900NXS2?
Thanks!
Posted Sun 19 Jan 25 @ 6:00 am
With the mapping window open, move the knob you want to use, and if it sends midi, it should show up in the top right box of the mapping window.
There you can just click it, and then map it how you want in the 'Action' box.
Posted Sun 19 Jan 25 @ 6:03 am
Oh lord it took you to tell me how fkn easy it was....Unfortunately I do not own the mixer thus I will need to wait until I will be at the club once again...but I will give it a try!
Thanks!
Posted Sun 19 Jan 25 @ 6:05 am
Locodog also told you already in this topic that the specific key name is fx_sendreturn_level, so you can also select that from the 'Key' drop-down or the list on the left directly.
Posted Sun 19 Jan 25 @ 6:15 am
thanks guys you are the best!
Posted Sun 19 Jan 25 @ 6:25 am
IT WORKS WOW!!!!!! thanks guys 🙏🏾
Posted Mon 20 Jan 25 @ 3:18 pm
It's soooo nice ❤️🟦❤️
Posted Thu 23 Jan 25 @ 5:06 pm
