Forum: VirtualDJ Plugins
Topic: Milk drop 64 Bit - Page: 3
When is it ready for 64bit ?
I need it ;-)
I remember us talking about the "project M"..but will this run in vdj as a pluging?
good find ^^ this one may somehow work as it is "spout complient"
projectM isn't an ideal replacement for Milkdrop on Windows as it's OpenGL based. Your options there would be to screen grab it, write a spout wrapper or manually wrap it and share the texture.
NestDrop looks pretty nice, might be an ideal solution.
I've released an early beta of Milkdrop for 64-bit windows users now - consider it a late christmas present!
I have test the Nestdrop with the Spout 2003 Plugin , the shows only a a little Video Window on my fullscreen Monitor...
And the Projekt M is only for Standalone use , and not good practible when I make Musik .... The Milkdrop I can change the Visuals with the FX Slider , thats better for use ;-)
Where can I get this 64 bit Milkdrop , hope to use it and test it :-) ?
Greetings Dani
I dont see it under downloads so it must be in a future update...Right?
Nice, and light ^^ once again (and as usual) very good work from SBDJ ^^
Everything seems to work (not all presets and not 4K tested)
As said some preset do not render, some take a long time to appear, some are very dark
not any integration problem when during tests in decks
hangs or crashes VDJ as V-Source :|
No preset selection slider is the only missing feature
Thanks for this one
Same here, can't find it
It's on his own site, not here (it's a beta remember).
The thing is, it doesn't seem possible to access the download unless you're registered on the site (forum) but it's not sending out confirmation emails.
not released as it is early beta
only found on SBDJ personnal website
I know thats a beta , i have read.
Where is this personal Page , not seen?
Go to his home page (here) and you'll see.
not sure if new signers can test betas from his site. [they couldn't before, but that might have changed]
I've got it here, but it's a very early beta, I'm not even going to start giving feedback until after NYD, because scott still has things to fix he knows about, and I doubt he'll be looking at it before the NY
Have now registred there , now wait for activate my username
The issue is that I'm not getting the email required to confirm my signup. I've resent multiple times.
same here..hmmm
I've tweeted him about it....
58%
