So you got it to work inside Virtual DJ? I tried again, still nothing. I'll probably just go on the SBDJ forum to figure it out. Thanks
Posted Sun 11 Dec 22 @ 1:03 am
You can't type directly in VDJ, as the keyboard feeds the browser. You have to type into/onto the floating Milkdrop monitor window.
Posted Sun 11 Dec 22 @ 9:15 am
I can't get it to work. I'm pressing 2 digit codes, pressing Y and then 2 digit codes. I get nothing
Posted Tue 13 Dec 22 @ 5:51 pm
SBDJ wrote :
It was a closed beta, but I've made it public beta now.
Hello.
How are you, hope everyone is fine.
I have the latest Milkdrop 301 Public Beta.
So far it's going great.
One little thing though.
If I open the engine to zb. to select a specific preset , then I have to do this to press L .
However, when I do that, the microphone also displays the text in the video on the main monitor, and not just in the engine window as it should.
And then is there a possibility to keep the engine window on top when open, i.e. above the VDJ skin?
Greetings Dani
Posted Mon 28 Aug 23 @ 6:08 pm
