try the sound setup in vdj or in the cpu. and im not sure of what VST is about.
Posted Thu 27 Jan 11 @ 6:39 pm
This is my favor Skin! ;-)
Posted Fri 28 Jan 11 @ 1:46 am
Please notify me when this is available. I'm interested in using this touch skin on my ProDJPC (http://www.prodjpc.com). I'm interested in going 100% touch to simplify my setup... I tried going 50/50 last weekend (half touch using ProDJPC's skin, half controller/mixer) the problem is that you get stuck in "limbo", I confused myself with feelings like, "which one should I use???". It's hard to use both at the same time IMO.
Posted Mon 31 Jan 11 @ 7:49 am
Mixing using just a touchscreen is not the easiest thing in the world, since VDJ doesnt support multitouch features yet. It depends on the way you mix. The best solution is to use an analogue mixer plus a touchscreen for all the other actions.
Anyway. I am in a middle of a couple of other skin projects for the time, so the 16:10 & 16:9 version will be ready in a month i guess.
Posted Mon 31 Jan 11 @ 8:34 am
this project your new skin. Ideal for touch screens. Primary and 1024x768 resolutions.
It seems in Video No front page of the forum,there it link
This is my new skin project. Ideal for touch screens. Primary resolutions 1280X1024 & 1024X768.
Video support too but not ready yet.
Posted Tue 01 Feb 11 @ 2:38 pm
I wonder if it will take long to come out with a resolution of 1366x768 skin virtual touch
Posted Thu 10 Feb 11 @ 3:35 pm
Posted Thu 10 Feb 11 @ 5:14 pm
I am grateful for the response,and congratulations again for the great job
Posted Fri 11 Feb 11 @ 11:31 am
You won't wait too much..
Available now
VirtualTouch X-Wide
Download Link
http://www.virtualdj.com/addons/12737/VirtualTouch_X-Wide.html
Resolutions
1366X768 & 1600X900 X-Wide (16:9)
The skin is based on VirtualTouch (1280X1024), but as you may notice, it was redesigned from scratch. Quite a few things have been changed to fit to the new ratio.
Additional features
- Hot Cues are now 4
- New Sampler Panel
- New Round sliders for Fxs, eq, filter etc
- New multibutton panel with 18 buttons with User Defined actions to customize the skin.
- Added Prelisten button and prelisten songpos bar
- Next automix song details are displayed on decks
- Added files view options (show audio, video, karaoke files)
- Added Status Bar
- Different color on focused browser window
- Video deck previews show up when video is enabled (automatic)
So its time to use your touchscreens ..lol !
Enjoy !
Available now
VirtualTouch X-Wide
Download Link
Resolutions
Additional features
- New Sampler Panel
- Added Status Bar
Enjoy !
Posted Mon 14 Feb 11 @ 8:58 pm
Some screenshots .. just to tease you :P
Decks panel
Browser panel
Decks panel
Browser panel
Posted Mon 14 Feb 11 @ 9:01 pm
Very impressive, Great job you are doing, you're definitely a KeyMan in the skin department.... Wow....
Thank You...Thank You...Thank You....
Joey...
Joey...
Posted Mon 14 Feb 11 @ 10:32 pm
this is awsome. but it keep crashing. i guess i am not suppose to use it. great job anyway.
Posted Tue 15 Feb 11 @ 11:26 am
If your resolution is not listed above then you cant use it. What is your resolution?
I'm about to make another version, this time 16:10 to cover 1280X800 & 1440X900
You cant resize the skin using the browser option. You can resize it only using simple resize mode.
Posted Tue 15 Feb 11 @ 12:47 pm
1366x768 thank u for responding so quick . 2 things is it cause im a limited ed. user and or i do not have a touch screen. i had the same trouble w the other skin. thanks
Posted Tue 15 Feb 11 @ 2:59 pm
It doesn't matter if you have a touchscreen or not ..:P
Do me a favor please. Download the Free version 7 http://www.virtualdj.com/download/free.html and try again. I'm too curious about it.
Posted Tue 15 Feb 11 @ 6:05 pm
VirtualTouch X-Wide 1366x768
I want to open the skin and vdj leaves east error to me?
That I do?
That I do?
Posted Tue 15 Feb 11 @ 6:50 pm
What a great looking skin, Same thing happens to me when I try to open the skin 1366 X 768 vdj crashes and you get a recover or shutdown error.
It will open up in 1600 x 900 but it is way to big for my screen size 1366 X 768. Any help how to get this skin running would be great.
Posted Wed 16 Feb 11 @ 2:27 pm
Ok i'll try to fix this, but i need your help to understand what's going on, since all resolutions run here pretty smooth.
So, in case you want to help, please answer to those questions.
1. What is your selected resolution, and which skin resolution are you trying to load. (VirtualTouch or VirtualTouch X-Wide)
2. Which skin is loaded before you load VirtualTouch
3. Before you change skin do you run VirtualDJ in maximized mode?
4. Does it still crashes if you Run VirtualDJ in not maximized mode? (Click on the maximize icon and check if you can use the grabzone)
5. Which panel is showing first (if any is showing) before crash?
6. Please post the contents of the crashguard report here. (You will find the txt file in MyDocuments/VirtualDJ folder)
Thank you
Thank you
Posted Wed 16 Feb 11 @ 2:58 pm
Posted Wed 16 Feb 11 @ 4:01 pm
Thank you for your help. I'll be waiting some more feedback from other users too, in order to gather more infos about this.
Posted Wed 16 Feb 11 @ 6:58 pm
