That might be problem with the hole serie. Dell knows to do that :)
Posted Thu 20 Nov 08 @ 11:41 am
Question - do the guys on here using Macs have any of these problems as I'm seriously thinking of going down that route (need to get a refund from Dell and save some extra money first).
Does the Macbook work OK? Seems to be integrated graphics with shared memory, or, is the Macbook Pro better with 2 graphics cards (and even more expensive)
Right, gonna trawl the Mac thread............
Posted Thu 20 Nov 08 @ 5:12 pm
Just a tip...if you can afford to spend a few bucks more for the GOLD Service Warranty....do it! You get top notch service and you speak to AMERICANS!! Makes a world of difference. In the mean time I'll stay away from the studio series.
Posted Thu 20 Nov 08 @ 8:07 pm
Well I had some time on my hands today, and wanted to do some maintenance on my gig machine (Dell XPS M1730).
So, I blatted it and loaded XP. Configured up the system, same issue as before, ~30% CPU used by hardware interrupts at all times. Reinstalled several times experimenting a bit with ATA/AHCI and other things, when managed to get XP running normally with 0% CPU usage at idle. DPC latency checker was in the green as well. Had to disable onboard sound to bring the latency down a bit. Installed VDJ, hit up audio, working perfectly. Video, also perfect, no freeze. As soon as I tried to use advanced master tempo however, it went to crap and I couldn't sort it.
Reinstalled Vista, couldn't get DPC to stay in the green this time, even with hardware disabled and no drivers installed. Played around a bit, but couldn't get the latency stable. Interestingly no video freeze present this time.
Reinstalled XP again, same as before, everything working except master tempo. At this point I ran out of time to play, so took a backup machine (Core2Quad 2.4GHz, X1950 Pro) which performed flawlessley.
Posted Thu 20 Nov 08 @ 9:38 pm
So what other laptop would you recomend other than a mac pro, please advice with what specs need to have in it as well as manufacture
Thanks
Thanks
Posted Fri 21 Nov 08 @ 6:59 pm
Thanks
I outfitted my 4th rig with a Dell Vostro laptop last December. It was scary because the Vostro series just launched last year, but it runs my program with the 4500 perfectly. Duo Core, 2 Gig of ram, 256 Video card and XP.
Thanks
Posted Fri 21 Nov 08 @ 10:10 pm
I outfitted my 4th rig with a Dell Vostro laptop last December. It was scary because the Vostro series just launched last year, but it runs my program with the 4500 perfectly. Duo Core, 2 Gig of ram, 256 Video card and XP.[/quote]
are you able to scratch video and not have it freeze? my issue with my super computer (thats what hercules tech support called it! lol) is the video will play but then the vidoe freezes. the music on the video plays and if i scratch that jog wheel it picks up right where the audio is..
audio only tracks are fine..
i have a xps 1530 with 4gb ram, duo core 2.53 ghz 512 nnvidia card...
Posted Fri 21 Nov 08 @ 10:14 pm
Try updating DirectX 9 August 2008 edition and new NVIDIA drivers.
Which codec pack do you use? I recommend K-Lite.
Posted Sat 22 Nov 08 @ 10:29 pm
is this info for me? my post above? let me know where i can get klite... ill see if i can grab the latest nnvidia drivers again....
Posted Sat 22 Nov 08 @ 10:45 pm
Yes for you, I didn't quoted you because your post was last ;)
Here are the links:
K lite
http://www.free-codecs.com/download_soft.php?d=4865&s=95
DirectX November 2008 edition:
http://download.microsoft.com/download/0/d/3/0d307649-9967-49fa-ab27-61f11024e97f/directx_nov2008_redist.exe
Latest drivers for your video card on www.nvidia.com
Here are the links:
K lite
Posted Sun 23 Nov 08 @ 7:55 am
AT LAST A RESULT FROM DELL!!!
They are collecting the Dell Studio 1535 laptop up on Thursday and going to give me a refund!!! Result!
Now, what laptop next???
Posted Tue 25 Nov 08 @ 10:40 am
Nice one mate, I would say that's a result.
Have a good look at the Toshiba range of laptops, one of the best manufactures of laptops in my book. My old gig laptop was a Toshiba (XP), used it for over a year, with no problems what so ever. In fact it's still going strong now.
I've got a Acer now with Vista. It's not bad now, but it took some setting up though.
But Toshiba mate, can't fault them.
Posted Tue 25 Nov 08 @ 12:35 pm
hey DJSoulman,
How did you check the dp latency on the ddell studio, i got one a wk ago 1537 studio, i just want to see if mine is going to give me that problem also
Posted Tue 25 Nov 08 @ 3:21 pm
Here is the DPC Latency Checker:
http://www.thesycon.de/deu/latency_check.shtml
Posted Tue 25 Nov 08 @ 8:00 pm
thanks
Posted Wed 26 Nov 08 @ 12:29 pm
ok what my dpc is 4000us is its in the red, is that bad, can some 1 explain what dpc is and what it does,
Thanks
Thanks
Posted Wed 26 Nov 08 @ 3:23 pm
http://www.thesycon.de/deu/latency_check.shtml . tells you all you need to know about the program. yes in the RED is not good. read the analysis in the program under the graph. it gives you an idea of what going on. use process explorer as well to check on the running processes...
Posted Wed 26 Nov 08 @ 3:27 pm
I totally disadvise Acer : very low quality ;-)
Better to buy laptops like Toshiba or Asus
Posted Wed 26 Nov 08 @ 3:54 pm
ok i read it, but its french to me, i still dont get what are drop out, and what does that cuz when your djing
Please can some 1 give me the 101 on DPC Latency and why it should not be in red.
Thanks
Thanks
Posted Wed 26 Nov 08 @ 3:55 pm
are HP pretty good,
Posted Wed 26 Nov 08 @ 3:57 pm
