Forum: Old versions
Topic: time code signal 0% please help - Page: 1
Hi,
i am using virtual dj 5.0 rev 7 and maya 44 usb sound card.
i have 2 problems
1: song plays too fast like chipmunks
2:0% timecode signal
Please help
Posted Tue 18 Mar 08 @ 8:09 pm
sory i forgot to mention i am using cd time codes
Please, register! Then you'll get help hier :-)
Not only should you register, but we need to know specs of your computer and what type of soundcard you are using. But more importanly REGISTER!!!!!!!!!!!!!!!!!!!!
computer p4 2.4 ghz 1.2 gig of ram
sound card=maya 44 usb as already mentioned above
Are you using a trial version?
You know who could really lend you a hand?? A Man and His Music....too bad he is dead to you, as you say.....
no a buddy of mine went on vacation and left his pc with me and he has the pro version on the pc but i have no idea if he is regestered on
these forums.Anyway i wanted to try the timecode on his pc and it was okay with hime but he has no experience with this.
@Tearemup
i am sure others could help, for instance you maybe....
Moderated by Lady Cameron
Sorry findasong no email address is allowed from a demo user
what email address ???
Alrighty , what cartridges do you use? are you using cd ?
If Cd which model?
How does the waveform look , big or small?
On Config > Performances
have you tried fastest and autolatency?
have you ensured your setup is correctly grounded?
which version of the maya driver do you run?
Hi,
i use cd's and my auto latency is on and the wave is too big.I use the latest drivers for my soundcard
ok thanks i will try that and get back to you
Thanks again
Hi,
it finally works but how come i get a beep sound right before the song starts ?
Try turning off Keylock.
keylock has always been off
any other suggestion ? since the problem still exists
Go to the maya control pannel and mute the volume of the inputs of the maya that way the timecode signal wont come out the speakers.
I would also suggest you uninstall what ever version you are using and try the latest demo version published in the last few days.
muting the input volume mutes the volume totally so this does not help.
I have the latest version rev 7
The funny thing is has alway happened to me in the earlier versions.
Any suggestions ?
Could it have anything to do with my cd players
Then you are muting the wrong parts.
You need to mute the MONITOR or line/phono in, at your maya control pannel, and NOT the line out/master out.
This is the way to mute the play-through of the timecode signal itself, to your master out
74%
