Hi,
i am using virtual dj 5.0 rev 7 and maya 44 usb sound card.
i have 2 problems
1: song plays too fast like chipmunks
2:0% timecode signal
Please help
i have 2 problems
Please help
Posted Tue 18 Mar 08 @ 8:09 pm
sory i forgot to mention i am using cd time codes
Posted Tue 18 Mar 08 @ 8:11 pm
Please, register! Then you'll get help hier :-)
Posted Wed 19 Mar 08 @ 3:20 am
Not only should you register, but we need to know specs of your computer and what type of soundcard you are using. But more importanly REGISTER!!!!!!!!!!!!!!!!!!!!
Posted Wed 19 Mar 08 @ 12:52 pm
computer p4 2.4 ghz 1.2 gig of ram
sound card=maya 44 usb as already mentioned above
Posted Wed 19 Mar 08 @ 3:22 pm
Are you using a trial version?
Posted Thu 20 Mar 08 @ 2:11 pm
You know who could really lend you a hand?? A Man and His Music....too bad he is dead to you, as you say.....
Posted Thu 20 Mar 08 @ 4:07 pm
no a buddy of mine went on vacation and left his pc with me and he has the pro version on the pc but i have no idea if he is regestered on
these forums.Anyway i wanted to try the timecode on his pc and it was okay with hime but he has no experience with this.
@Tearemup
i am sure others could help, for instance you maybe....
Moderated by Lady Cameron
Sorry findasong no email address is allowed from a demo user
@Tearemup
Posted Thu 20 Mar 08 @ 5:33 pm
what email address ???
Posted Fri 21 Mar 08 @ 10:40 am
Alrighty , what cartridges do you use? are you using cd ?
If Cd which model?
How does the waveform look , big or small?
On Config > Performances
have you tried fastest and autolatency?
have you ensured your setup is correctly grounded?
which version of the maya driver do you run?
If Cd which model?
Posted Fri 21 Mar 08 @ 5:53 pm
Hi,
i use cd's and my auto latency is on and the wave is too big.I use the latest drivers for my soundcard
Posted Fri 21 Mar 08 @ 5:58 pm
http://www.virtualdj.com/products/timecode/cd.html
You need the pro grade time code download this one and burn it to cd.
Some cd players produce a very loud output and this distorts the signal.
Posted Fri 21 Mar 08 @ 6:07 pm
ok thanks i will try that and get back to you
Thanks again
Thanks again
Posted Fri 21 Mar 08 @ 6:09 pm
Hi,
it finally works but how come i get a beep sound right before the song starts ?
Posted Fri 21 Mar 08 @ 6:16 pm
Try turning off Keylock.
Posted Fri 21 Mar 08 @ 6:19 pm
keylock has always been off
any other suggestion ? since the problem still exists
Posted Fri 21 Mar 08 @ 6:32 pm
Go to the maya control pannel and mute the volume of the inputs of the maya that way the timecode signal wont come out the speakers.
I would also suggest you uninstall what ever version you are using and try the latest demo version published in the last few days.
Posted Fri 21 Mar 08 @ 6:34 pm
muting the input volume mutes the volume totally so this does not help.
I have the latest version rev 7
The funny thing is has alway happened to me in the earlier versions.
Any suggestions ?
Could it have anything to do with my cd players
Any suggestions ?
Posted Fri 21 Mar 08 @ 6:43 pm
Then you are muting the wrong parts.
You need to mute the MONITOR or line/phono in, at your maya control pannel, and NOT the line out/master out.
This is the way to mute the play-through of the timecode signal itself, to your master out
Posted Fri 21 Mar 08 @ 6:48 pm
