Forum: VirtualDJ Plugins
Topic: Slideshow picture stretched V5 [SOLVED] - Page: 8
GilbzPRO InfinityMember since 2006
TopHouse wrote :
Gilbz wrote :
Scott when will this be available?
I have sod all to do Monday so I can give it a good thrash at home
I do wish you'd keep your sexual practices to yourself Lee!!
Oh, here's that item you were asking about :-
Lee's Item Link
Why was that link to do with a hamster?! Mr Pee Wee!
Anyway back on topic!
I already have that plugin.
Posted Sun 17 Feb 08 @ 8:34 am
SBDJPRO Infinity Member since 2006
I've got some debugging to do based on feedback from Kym, I'm trying to narrow down why certain conditions would cause a crash. I'm going to write a whole bunch of safety code, and add a "Debug" button for the beta versions that will log what is happening so hopefully we can catch it. I'll have that version ready and uploaded early this week :)
Regards,
Scott
Posted Sun 17 Feb 08 @ 11:57 am
How do you even activate it, I see no controls on mine?
Posted Sun 17 Feb 08 @ 5:02 pm
Have a look at these posts...
djcel wrote :
I'm sure it is a problem of dll missing on their computers, I guess MSVCR80.dll, due to:
http://www.wireshark.org/docs/wsdg_html_chunked/ChToolsMSChain.html
They have to download and install:
http://www.microsoft.com/downloads/details.aspx?familyid=200B2FD9-AE1A-4A14-984D-389C36F85647&displaylang=en
tanina wrote :
Hello everyone with problems with the SBDJ Slideshow controls not showing up. I took a gamble and put my console online. I updated windows until I had no more updates available in Express and Custom. I just opened the SBDJ Slideshow and guess what. IT HAS CONTROLLLLLSSSSS!!!!!!! Yippee!
Try it and I hope it works for you.
Now, I'm going to start testing everything.
Let me know if you don't get any luck...
Regards,
Scott
Posted Sun 17 Feb 08 @ 6:14 pm
OUCH!!!! I installed the compiler as you stated in the links, now when opening VDJ I get the error message:
"The application failed to start because d3dx9_36.dll was not found.
Now what do I do?
Also, I installed the latest 9.0c Nov.2007 on top of the june 2007 one I had?
Am i screwed! I can't get VDJ to work at all? Please help!!
Posted Tue 19 Feb 08 @ 5:50 pm
Is it the new 9.0c direct X that is causing this, and do I need to go back to the older June 07 version I have, and if so, how do I do that w/o havio do system restore?
I'm helpless until I get some help, please.
Posted Tue 19 Feb 08 @ 6:44 pm
It's not the nov directx that's stopping VDJ, you could try reinstalling the directx patch and see if that cures it.
Posted Tue 19 Feb 08 @ 7:16 pm
It's not the compiler runtime links above; it's your DirectX thats the problem.
It sounds to me like it's not updated properly. Can you list all the files in your c:\windows\system32 folder called d3dx9_XX.dll please (where XX will be two numbers)? I think 36 was one of the files in the November 2007 update, which likely means it wasn't installed correctly. I would run the DirectX web update if I was you to start with.
I didn't think VDJ was compiled against this file though, so remove the video plugins and see if VDJ will open then...
Regards,
Scott
Posted Tue 19 Feb 08 @ 9:50 pm
djcelPRO InfinityModeratorMember since 2004
When you start VirtualDJ, the software will load the selected sound/video/transition plugins
Posted Wed 20 Feb 08 @ 6:39 am
What happens is: VDJ starts up if I hit ok.
But the error comes back wjen I click on the new slideshow plugin.
Then I deleted the plugin and everything was okay.
Why would that occur?
Posted Wed 20 Feb 08 @ 10:22 am
DirectX9.0cNov.2007\ (78) 02-19-2008 18:26:14
Apr2005_d3dx9_25_x64.cab 10-22-2007 03:31:02
Apr2005_d3dx9_25_x86.cab 10-22-2007 03:31:02
Apr2006_d3dx9_30_x64.cab 10-22-2007 03:31:02
Apr2006_d3dx9_30_x86.cab 10-22-2007 03:31:02
Apr2006_MDX1_x86.cab 10-22-2007 03:31:02
Apr2006_MDX1_x86_Archive.cab 10-22-2007 03:31:02
Apr2006_XACT_x64.cab 10-22-2007 03:31:02
Apr2006_XACT_x86.cab 10-22-2007 03:31:02
Apr2006_xinput_x64.cab 10-22-2007 03:31:02
Apr2006_xinput_x86.cab 10-22-2007 03:31:02
APR2007_d3dx10_33_x64.cab 10-22-2007 03:31:02
APR2007_d3dx10_33_x86.cab 10-22-2007 03:31:02
APR2007_d3dx9_33_x64.cab 10-22-2007 03:31:02
APR2007_d3dx9_33_x86.cab 10-22-2007 03:31:02
APR2007_XACT_x64.cab 10-22-2007 03:31:02
APR2007_XACT_x86.cab 10-22-2007 03:31:04
APR2007_xinput_x64.cab 10-22-2007 03:31:04
APR2007_xinput_x86.cab 10-22-2007 03:31:04
Aug2005_d3dx9_27_x64.cab 10-22-2007 03:31:04
Aug2005_d3dx9_27_x86.cab 10-22-2007 03:31:04
AUG2006_XACT_x64.cab 10-22-2007 03:31:04
AUG2006_XACT_x86.cab 10-22-2007 03:31:04
AUG2006_xinput_x64.cab 10-22-2007 03:31:04
AUG2006_xinput_x86.cab 10-22-2007 03:31:04
AUG2007_d3dx10_35_x64.cab 10-22-2007 03:31:04
AUG2007_d3dx10_35_x86.cab 10-22-2007 03:31:04
AUG2007_d3dx9_35_x64.cab 10-22-2007 03:31:04
AUG2007_d3dx9_35_x86.cab 10-22-2007 03:31:04
AUG2007_XACT_x64.cab 10-22-2007 03:31:04
AUG2007_XACT_x86.cab 10-22-2007 03:31:04
BDANT.cab 10-22-2007 03:31:02
BDAXP.cab 10-22-2007 03:31:02
Dec2005_d3dx9_28_x64.cab 10-22-2007 03:31:04
Dec2005_d3dx9_28_x86.cab 10-22-2007 03:31:04
DEC2006_d3dx10_00_x64.cab 10-22-2007 03:31:04
DEC2006_d3dx10_00_x86.cab 10-22-2007 03:31:04
DEC2006_d3dx9_32_x64.cab 10-22-2007 03:31:04
DEC2006_d3dx9_32_x86.cab 10-22-2007 03:31:04
DEC2006_XACT_x64.cab 10-22-2007 03:31:04
DEC2006_XACT_x86.cab 10-22-2007 03:31:04
DSETUP.dll 10-22-2007 03:31:06
dsetup32.dll 10-22-2007 03:31:06
dxdllreg_x86.cab 10-22-2007 03:49:48
dxnt.cab 10-22-2007 03:31:02
DXSETUP.exe 10-22-2007 03:31:06
dxupdate.cab 10-22-2007 03:31:06
Feb2005_d3dx9_24_x64.cab 10-22-2007 03:31:04
Feb2005_d3dx9_24_x86.cab 10-22-2007 03:31:04
Feb2006_d3dx9_29_x64.cab 10-22-2007 03:31:04
Feb2006_d3dx9_29_x86.cab 10-22-2007 03:31:04
Feb2006_XACT_x64.cab 10-22-2007 03:31:04
Feb2006_XACT_x86.cab 10-22-2007 03:31:04
FEB2007_XACT_x64.cab 10-22-2007 03:31:04
FEB2007_XACT_x86.cab 10-22-2007 03:31:04
Jun2005_d3dx9_26_x64.cab 10-22-2007 03:31:04
Jun2005_d3dx9_26_x86.cab 10-22-2007 03:31:04
JUN2006_XACT_x64.cab 10-22-2007 03:31:06
JUN2006_XACT_x86.cab 10-22-2007 03:31:06
JUN2007_d3dx10_34_x64.cab 10-22-2007 03:31:06
JUN2007_d3dx10_34_x86.cab 10-22-2007 03:31:06
JUN2007_d3dx9_34_x64.cab 10-22-2007 03:31:06
JUN2007_d3dx9_34_x86.cab 10-22-2007 03:31:06
JUN2007_XACT_x64.cab 10-22-2007 03:31:06
JUN2007_XACT_x86.cab 10-22-2007 03:31:06
NOV2007_d3dx10_36_x64.cab 10-22-2007 03:49:50
NOV2007_d3dx10_36_x86.cab 10-22-2007 03:49:48
NOV2007_d3dx9_36_x64.cab 10-22-2007 03:49:52
NOV2007_d3dx9_36_x86.cab 10-22-2007 03:49:48
NOV2007_X3DAudio_x64.cab 10-22-2007 03:49:48
NOV2007_X3DAudio_x86.cab 10-22-2007 03:49:48
NOV2007_XACT_x64.cab 10-22-2007 03:49:48
NOV2007_XACT_x86.cab 10-22-2007 03:49:48
Oct2005_xinput_x64.cab 10-22-2007 03:31:06
Oct2005_xinput_x86.cab 10-22-2007 03:31:06
OCT2006_d3dx9_31_x64.cab 10-22-2007 03:31:06
OCT2006_d3dx9_31_x86.cab 10-22-2007 03:31:06
OCT2006_XACT_x64.cab 10-22-2007 03:31:06
OCT2006_XACT_x86.cab 10-22-2007 03:31:06
They appear to be mostly d3dx9_36_x64 or x86
The error was looking only for d3dx9_36.dll
Posted Wed 20 Feb 08 @ 10:47 am
I meant the actual files in your windowssystem32 folder; the x86 or x64 files are cab files and contain the relevant DLLs ;)
The problem occurred because your DirectX November 2007 update is not installed correctly.
Posted Wed 20 Feb 08 @ 11:25 am
Just click on DXSETUP.exe
Posted Wed 20 Feb 08 @ 1:10 pm
Thanx, CDcel, I did that and no mor error message. However, althoughthe controls are there,
I CANNOT open a folder and activate the slideshow.
I went to the other original slideshow and that activated and opened a folder correctly.
Th "open" button seems to do nothing when clicked on it?
Posted Wed 20 Feb 08 @ 4:48 pm
Also, after I finally get ths working, I would like to set up on my Show machine.
Do I ALSO have to install the net3.0 update (I have 2.0 now, I believe)?
AND, do I also HAVE to install that compiler vcredist_x86?
I just don't want to put anything in my show machine that I don't absolultely have to.
Posted Wed 20 Feb 08 @ 4:59 pm
Not sure, but would having my video on single screen make the difference.
This machine is NOT hooked up to a second monitor and the original slideshow functions well enough as I can see the
pictures in the lower right video square on this screen.
Posted Wed 20 Feb 08 @ 5:10 pm
li125PRO InfinityMember since 2005
I just had a try with the slideshow funtion. Needed to upgrade first DirectX to nov2007 (had errors 3d3...) but works fine now. Nice,
I missing 2 option:
-maintain aspect ratio
-show full screen or original size.
Posted Wed 20 Feb 08 @ 5:43 pm
I think the whole purpose of this new slideshow is to mantain the aspect ratio, I don't see those controls either?
Posted Thu 21 Feb 08 @ 1:01 am
I don't think those controls are in the download version as yet.
Scott is still doing testing/ writing the latest version
Posted Thu 21 Feb 08 @ 4:15 am
Bryan I had the same problems and I think the reason I found was the folder had too many pictures in it.
From going back through this thread anything above 200 pics you will get problems. In my case I clicked 'open' on the folder I wanted to show and nothing happened.
Tried to click 'open' again and it wouldn't do anything.
So I shut VDJ down and done it all again but picked a folder with less pics and all seems fine.
Posted Thu 21 Feb 08 @ 4:18 am
64%
