GuiYeYDJ wrote :
i forget ask for use for DATA button, CLEAR aparently do nothing and NUKE delete all tags, maybe Clear must delete only feature who is located now...example if i was in genre only delete all genres from this track...
See explainer post for each button function
to delete a whole tag; right click the tag button [only works in marking mode]
Clear is not used much, it clears the undo memory and clears the data button
Data button is a grab feature that will be needed very rarely, also explained in post.
Posted Fri 03 Jul 26 @ 9:28 pm
locoDog wrote :
Figured 2 solutions, weighting up which way is better.
I'm guessing you're mac?
I'll see what I can do about those rating stars not rendering.
Could you do me a full screen shot of bother mark & filter panels, just so I can see what needs fixing for mac
I can't tell if boxes aren't being bordered or if bordercolor is a close match to dennys background that it make border invisible.
I´m on windows, no worry about stars, i did a modify skin color scheme dayight , and convert it in my custom skin color scheme. if i set skin color scheme to contrast or default the stars are normally showed.
About script you write, it´s usefull, thanks.
at last sorry for ask you what was very detailed explained in the thread.
think don´t need capture, but don´t cost nothing do it.
Posted Sat 04 Jul 26 @ 12:05 am
solved issue when "0" was selected on any tag, here bringa capture what i was triying to explain in mp.
lets we tag tag tag tag...like crazysss!!!
Posted Sat 04 Jul 26 @ 10:10 pm
Yeah until you assign something to the variable it == 0, it's actually == no data but the script engine doesn't make it easy to tell the difference.
Just interacting with a variable of no data turns it into a data of type float == 0.000
that's why buttons are blank until you right click and then magically a zero appears.
Solved issue by checking if I can do maths on the variable, if I can it means it's not something that user typed in and can be ignored in LED logic [typed in numbers are text and can't do math directly on text]
Posted Sun 05 Jul 26 @ 1:46 am
@PANOSV @TSI
If you can write a tags list I can make you a button to populate
If you just want to free hand it, just let me know what skin you want it building in.
Posted Sun 05 Jul 26 @ 1:52 am
Ok awesome!! I use Georges skin and ill get a list to you today.
Posted Mon 06 Jul 26 @ 1:56 pm
@djjoe21 that fork you asked for has been sat in PM for a few days.
Posted Mon 06 Jul 26 @ 8:32 pm
locoDog wrote :
you mean regarding genres? subgenres?@PANOSV @TSI
Posted Wed 08 Jul 26 @ 10:31 am
see GuiYeYDJ & djjoe21's lists
sure genre - subgenre is one
but they're your tags and there are 3 more to use, you can use them for whatever works for you
energy scenario vibe
see my comment tag selection that I completely filled with vibe based adjectives
genre based filtering with vibe based optionals is when filtering starts getting good
it takes a while to reach a critical mass of vibes tagged but once you're there it gets powerful
"Ok I'm playing a track genred 'house' and the vibe is 'dirty' "
"let's try a filter like this;
( genre contains house or genre contains electro or genre contains techno ) & ( comment contains sleazy or comment contains dirty or comment contains dank )
but it's your tags and your time you can use as much or as little as you please.
Posted Wed 08 Jul 26 @ 11:05 am
