It would not have been installed automatically if you had early access disabled.
Posted Fri 22 Mar 24 @ 3:32 pm
I'm aware. So far I've never really had any problems with it. That's why I didn't think about turning off the beta update. But whatever. Now it has happened and I need a solution as quickly as possible.
Posted Fri 22 Mar 24 @ 3:35 pm
It's not beta, that is a separate testing regime altogether.
https://www.virtualdj.com/wiki/How%20can%20i%20get%20an%20Early%20Access%20or%20a%20Beta%20build.html
Posted Fri 22 Mar 24 @ 3:36 pm
OK. I didn't know that. As far as I know, I only selected Early Access. I was referred here by support and my bug report was also forwarded. I already mentioned it above. Now I'm curious to see what happens. If necessary I have to reinstall VDJ.
Posted Fri 22 Mar 24 @ 3:49 pm
When you are aware that you have a gig coming up, it's safest not to install ANY update to a working system.
Download the release version from https://www.virtualdj.com/download/index.html and then keep the file on your computer, so even if you do find yourself with an EA release at (or before) a gig, you always have a release build to install.
Posted Fri 22 Mar 24 @ 4:14 pm
The problem with this release though is that it changes quite a few things directory ways that aren't easily undone just by installing a previous build.
Posted Fri 22 Mar 24 @ 4:18 pm
That's another thing worth mentioning - keep backups :-)
Posted Fri 22 Mar 24 @ 4:21 pm
With the early release the playlists should now be in "Lists". Only some of the playlists are in that location.I found "Playlists" under music but it is empty..
My playlists are still in the Documents/Virtual folder.
How can I get the playlists to show in the new version?
Posted Fri 22 Mar 24 @ 6:12 pm
Wow Virtual DJ you creative genius always showing out, I love the new update. To have the flexibility with the cloud management is amazing. Thank you to all who continue to work hard to make this software even better.
Posted Sat 23 Mar 24 @ 7:56 am
When I use clouddrive sync (dropbox based) on a list that includes tracks with prepared stems, and use sync on another laptop, VDJ seems to download the stems file from cloud on each track load (it says so in the info line), although according to the file explorer on the second the files are already downloaded and available
Are they not pre-downloaded by dropbox although they appear to be?
On the "original" laptop the stems are of course instantly available when loading the track
Posted Sat 23 Mar 24 @ 1:05 pm
Just a thought, people appear confused with the term "Early Access". Perhaps they are more used to the term Beta? Or maybe they just don't know they have EA ticked.
Posted Sun 24 Mar 24 @ 10:45 pm
There are also betas released and a beta tester program. They come before the Early Acces builds. But only beta testers can see/get them
Posted Mon 25 Mar 24 @ 4:32 am
stretch107 wrote :
I noticed after updating to VDJ 2024 all video tracks that I had cleaned have lost the video stream and just play audio now. any ideas?
Same here, I had to fall back to 7921; running on Mojave. I have not check on other macs that are running Ventura and windows running on 10 & 11, but yes on Mojave I have to restart VDJ to get back the videos.
Posted Mon 25 Mar 24 @ 6:14 pm
Can you open one of those broken vdjedit files from Finder using a Text Editor and post here the content of the vdjedit file ?
Posted Tue 26 Mar 24 @ 1:32 pm
new EarlyAccess version (b8044) should fix most of the issues that have been reported.
Posted Tue 26 Mar 24 @ 7:00 pm
In Version 8044 > sideviewShortcuts "geniusdj:linked" no longer works
Posted Tue 26 Mar 24 @ 8:34 pm
@Stephane Just a minor point. In your Changelog page the (Early Access) is listed as BUILD 8023. I have Early Access enabled and it arrived as BUILD 8044 It may confuse some people.
https://www.virtualdj.com/products/virtualdj/changelog.html?view=advanced
Posted Wed 27 Mar 24 @ 1:02 am
i'm not picky about designator as long as it works. and so far so good :-)
Posted Wed 27 Mar 24 @ 1:16 am
With the newest update the "List" no longer show up in SoundSwitch. Also broke the connection with LEXICON 🤦🏾♂️
Basically any sync software no longer works with the dreaded "lists"
Anything I can do to fix this??
Ok so I figured out how to export/create a playlist but this is terrible. So many steps.....
Posted Wed 27 Mar 24 @ 2:07 am
@tsi setting browserAutoExportM3U
Posted Wed 27 Mar 24 @ 2:41 am
