Hello there, i downloaded the latest version of Virtual DJ and the equalizer is acting weird. It isolates the highs/mids/lows rather than increase/decrease them. Im using a
Pioneer DDJ - 400. I need some help to fix it, Thanks.
Posted Sun 18 Apr 21 @ 12:17 pm
Its a new feature where you can easily remove vocals, or have vocals only etc.. .
You can turn that off on the EQs if you want, and revert to traditional EQ.
Click the small arrow at top of EQ section in default skin, and disable stems on EQs
See here:
https://virtualdj.com/manuals/virtualdj/interface/mixer/audio.html#eqmode
See here:
Posted Sun 18 Apr 21 @ 12:37 pm
