Can we get the Syphon Plugin for Mac fixed, Please. its been 2 years now. It never worked with 8.3 and now its the same with 8.4. Very kind regards, Kevin Hackett.
Posted Thu 12 Mar 20 @ 1:35 pm
I just purchased a Virtual DJ subscription on the assumption that Syphon output was supported since Virtual DJ has a ton of features and Serato Video supports Syphon output. Can you please fix the Syphon output plugin?
Posted Thu 12 Mar 20 @ 5:50 pm
The Syphon Client plugin should work fine, what happens for you when you try to run it?
Posted Thu 12 Mar 20 @ 6:16 pm
Been working for me for the last couple years!! I use it with Mix Emergency and Resolume, no problems here and I always am usi g the newest version of VDJ...
Posted Fri 13 Mar 20 @ 4:54 pm
He's talking about Virtual DJ running as a Syphon Server and not a Client which are two totally separate things. A Syphon Client can receive video from other programs but a Syphon Server can send video to other programs. If you want to do complex video mapping/keystoning multiple outputs for LED walls, etc you need Virtual DJ to support Syphon Server output.
Are you actually able to Syphon Virtual DJs output into Resolume? Does Virtual DJ show up as a Syphon input source for you in Resolume? AFAIK I haven't been able to get it to work. LuxLumen's workaround is to have Virtual DJ output a screen to a Blackmagic mini recorder capture card and then run that captured output into Resolume. Unfortunately with my setup (Macbook Pro 2019), i'm maxing out every port on my attached USB hubs while also running an EGPU. There's no way I can run a capture card as a work around which is why I would love for Virtual DJ to support output as a Syphon Server.
Posted Mon 16 Mar 20 @ 7:25 pm
Yes I can send video FROM VDJ too Resolume and Mix Emergency.
I could probably upload a video tonight showing you.
I’m using a 2013 MacBook Pro ..
Posted Tue 17 Mar 20 @ 11:18 am
Yes, please do. You could even tell me your method too. Are using a Mac, correct? I figure you can easily do this on a PC with Spout but I can't figure out a way to send it using Syphon on a mac.
Posted Thu 19 Mar 20 @ 12:31 am
No problem, I’ll have it up in a few hours for ya bud 🤙🏾
Posted Thu 19 Mar 20 @ 1:51 am
Feel free to ask ask any questions...
Posted Thu 19 Mar 20 @ 8:43 am
