Topic: sandbox
Since the new update has anyone noticed that the sandbox is either gone or not working. i use the denny o skin and mines not working
Posted Mon 23 Dec 19 @ 1:05 am
have you tried it on the default skin?
Cant find it on the new version 20
Same issue on my side.I have the essentials skin and sandbox is not opening anymore...it used to work fine on VDJ 8.
Cheers
Yea me too No more Sandbox...what is going on
Nothing has changed in regards to sandbox.
But the same limitations apply as before.
Sandbox will not operate in the following cases:
- The Audio Setup is configured as an external mixer (master/headphones configuration is required.)
- Already in the middle of a mix (more than one song is playing out on Master).
- Effects, samples or loops playing on the "active" deck.
- A Video file is playing in the active deck
https://virtualdj.com/manuals/virtualdj/interface/topsection/appcontrols/sandbox.html
Working as fine as usual here
even the bug is there.... (muted tracks are unmuted while entering sandbox mode)
