Topic: VDJ Equalizer Settings
Just wondering if anyone can share their EQ settings ( if adjusted).
I used to have a setting applied but my laptop crashed and I can't recall what the settings were I just know that it made the sound quality a lot better.
At the moment, I am using the default of
Low Frequency 200
Mid Frequency 1700
High Frequency 6500
Posted Thu 13 Dec 18 @ 12:04 pm
My Settings are.
Low : 100
Mid : 1350
High ; 15000
And Full Kill on.
Stumbled across this very old thread. Curious about the best settings for Denon MC6000
Depends whether you run it in internal or external sound card mode.
internal
The settings don't depend on your controller, but on your preference and type of mixing.
You can start with the defaults and then try higher or lower values to see what you like more.
I've had a bit of fun recently creating a pad page to implement a variety of settings emulating different mixers for comparison.
Using the script:
setting "equalizerLowFrequency" 200 && setting "equalizerMidFrequency" 1700 && setting "equalizerHighFrequency" 6500
with the specific values set for different mixers.
So for example there is one pad with the Virtualdj default values of:
Low : 200
Mid : 1700
High ; 6500
whereas the Pioneer emulator pad is set to:
Low : 70
Mid : 1000
High ; 13000
(Doesn't sound good IMO!)
My personal choice at the moment is:
Low : 300
Mid : 1375
High : 2700
which is based on a kind of Rane/Xone92/Xone 42 combo!
Hi everyone am DJ Sxuccess what is the best equalizer level Settings pls anyone with the idea? am waiting
There is no "the best". It's personal choice.
