Topic: Script School - Page: 17.25
Hello everyone. So, I have a few questions.
1) Play Next or automix_add_next - which of these 2 functions will be more suitable for me? You need to add a script to the task schedule:
add one (specific or random) file from the folder as follows! Let's call them * workfile (s), while it is located in one specific folder (or it can be a virtual folder). Next.... We expand the possibilities.... There are 72 files in that folder, 3 pcs. for each hour, i.e. you need to run a file every time that has not yet been played today.
2) Task schedule - This task must be repeated every 20 minutes during the day.
Let's start with this, if there is a correct solution, then I will continue to throw up interesting ideas.
Hi at all, how i map a button to change focus from browser_window “folders” to brower_window “songs” only if folders focus is in “sample Recording” file or inside the “sample” folder? i have mapped: get_browsed_folder ‘sample’ ? browser_window ‘songs’ : nothing
but doesn’t work :(
param_equal `get_browsed_folder` "YOUR_STRING" ? TRUE : FALSE
could also use
param_contains
with
get_browsed_filepath
if you need the query to not be as specific
if its only for samples they are virtual elements
param_equal `get_browsed_song extension` vdjsample ? browser_window songs
get_browsed_filepath & param_contains ‘Recordings’
is perfect! thanks for the script; i have another question:
with a button i would record max 9 files in folder ‘Recordings’, i have write this script:
browser_gotofolder ‘Sampler\Recordings’ & browser_window ‘songs’ & file_cont 10 ? nothing : sampler_rec ‘master’
but with this script i push 2 time button for recording…1 time for set folder focus in folder ‘Recordings’ and 2 time for recording from master….could i do this with script that record or not pushing only 1 time button? thanks a lot!
There is no answer or recommendation to my question?
@mg_1978
try
browser_gotofolder 'sampler://Recordings' & browser_enter & param_equal `file_count` 10 !? sampler_rec master
or add some delay for browser to end action if too slow
browser_gotofolder 'sampler://Recordings' & repeat_start dx 170ms 1 & browser_enter & param_equal `file_count` 10 !? sampler_rec master
take care about the count if some more 10 other records exist, script will do
may prevent by using
browser_gotofolder 'sampler://Recordings' & browser_enter & param_bigger `file_count` 9 ? sampler_rec master
@Nicotux
thanks a lot, your scripts works!
today my question is: if i use scripts like ‘mic_rec’ or ‘linein_rec’, in the deck there is the recorded…can i directly save a .vdj or .mp3 file (with script button that i don’t know) that is in my deck? or i can only put deck recorded in loop and use sampler_rec 1 (for example) to create a sample file .vdj? thanks
@mr.ZvooK, setting up adverts?
make a filter that grabs for your 72 files, also include & Last Play > 0.5
[use 0.5 as 1 would allow for no variety day after day]
Random is tricky, maybe when your 20 minute timer strikes, jump to your filter,
something like this to get a random number,
set test `param_mod "file_count" "get_time elapsed"`
then use test as the count for a rsi performing browser_scroll
JUMP TO FILTER & set test `get_clock 1000 & param_multiply 0.001 & param_cast 'frac' & param_multiply 1000` & set test `param_mod "file_count" "get_var test"` & var_smaller 'test' 0 ? param_multiply "get_var test" -1 & RSI WITH BROWSER SCROLL : RSI WITH BROWSER SCROLL
I forgot about get_clock 1000, probably the best way to get a random number.
have you any ideas??? thanks a lot
today my question is: if i use scripts like ‘mic_rec’ or ‘linein_rec’, in the deck there is the recorded…can i directly save a .vdj or .mp3 file (with script button that i don’t know) that is in my deck? or i can only put deck recorded in loop and use sampler_rec 1 (for example) to create a sample file .vdj? thanks[/quote]
TIP about complex actions in actions
( I don't know how site will accept this :\ )
Sometimes actions need to use result of actions and strings
they can use back quotes and quotes and apostrophes ( `xxx` 'xxx ' and "xx" )
when the result have to be display in a text or button or slider ....
the skin need to enclose it in quotes or apostrophes
text="" or format="" or action="" ...
this can be an issue
there is a standard workaround to this : remember xml entities : > < & " '
you can then write complex strings like that :
action="param_add `param_add "get_text ')' " 'param_add "get_automix_song artist +1"' " - (" ` `param_add 'get_automix_song title +1' "get_text ' Comming next : ' " ` & param_cast text"
hi at all, in my Pioneer DDj-RZX i have mapped 2 buttons like Rekordbox Sequencer..but i record from ‘master’ output…could i record from sampler output? for example i have mapped a button: sampler_rec ‘master’; i tried to write sampler_rec ‘sampler’ but doesn’t work :(; if i choose deck 3 output for sampler i tried to write button: deck 3 sampler_rec but doesn’t work :( can you help me? thanks!
deck 1 sampler_rec
works here, are you internal or external mixer?
locodog wrote :
deck 1 sampler_rec
thanks for answer, i have internal mixer mode, but deck 1 sampler_rec record track or loop or portion track that is in deck 1…i would record output about sampler…for example i would record sampler 1 playing + sampler 2 playing + sampler 7 playing, like a rekordbox sequencer…now i make this recordind master output…but i would record only sampler output…
so output to a deck not in use. If all 4 decks are in use there is the invisible deck option but it might confuse your workflow.
sorry deck1 sample_rec is perfect! recording all sound that flow in mixer channel 1 👏👏
question: can i record from sampler headphones? wich is correct script? sampler_rec ‘headphones’ or ‘headphones’ sampler_rec don’t works :(
answer; no not possible.
get_beat_bar & some applied maths.
May as well write something, and I last said, get_beat_bar, so what is it?
It returns a value between 0.0 & 1.0 to represent the current position of the current bar,
if it returns 0.25, you're exactly on the second beat, 0.5 third beat.
it accepts a parameter [any positive integer]
so get_beat_bar 1, returns 0.5 when you are half way between two beats
get_beat_bar 32, returns 0.5 when you are exactly on the 17th beat.
lets make something with it. How about an echo that turns itself off
effect_active 'echo' on & repeat_start 'rsEchoEnd' 30ms -1 & param_bigger `get_beat_bar 4` 0.03125 ? effect_active 'echo' off & repeat_stop 'rsEchoEnd' : nothing
nothing much to it, echo on, rsi started, when 0.03125 is bigger than what beat_bar 4 returns, turn the fx off and the rsi off
let's do something a bit more involved.
let's make the filter dial oscillate from off [50%] to 80% and back over 8 beats. button on button off
Without thinking we'll do the bits we can do without thinking, button on button off logic, is a rsi running? yes stop it : no so we'll start it
repeat_start_instant 'filtOsc' ? repeat_stop 'filtOsc' : repeat_start_instant 'filtOsc' 30ms -1 &...
we have some things to figure out. Lets think about going up from 0.5 to 0.8 first.
when beat_bar 8 returns 0.0 we want the filter to be 0.5
when beat_bar 8 returns 0.5 we want the filter to be 0.8
so 0.5 change from beat_bar is 0.3 change in the filter, so 3/5ths, multiply by 0.6, then add 0.5 because our filters start is 0.5
get_beat_bar 8 & param_multiply 0.6 & param_add 0.5 & param_cast & filter
test that on a button, it seems to work, but it breaks our design spec when beat_bar returns more than 0.5, let's check for beat_bar >0.5
param_bigger `get_beat_bar 8` 0.5 ? 0.5 is bigger than beat_bar, we have the script for that : 0.5 is smaller than beat_bar, we need to work out how to do that.
0.0 to 0.5 worked very well for the way up, how can we get 0.5 to 0.0 for the way down?
well, 1 - get_beat_bar 8 would do that but how to script that.
get_beat_bar 8 & param_multiply -1 & param_add 1 &
*SIDE NOTE AT THE END*
try it out on a test button
get_beat_bar 8 & param_multiply -1 & param_add 1 & param_multiply 0.6 & param_add 0.5 & param_cast & filter
seems ok when beat bar is > 0.5, lets combine both buttons and the >/< 0.5 check
param_bigger `get_beat_bar 8` 0.5 ? get_beat_bar 8 & param_multiply 0.6 & param_add 0.5 & param_cast & filter : get_beat_bar 8 & param_multiply -1 & param_add 1 & param_multiply 0.6 & param_add 0.5 & param_cast & filter
Strap it all together, job done
repeat_start_instant 'filtOsc' ? repeat_stop 'filtOsc' : repeat_start_instant 'filtOsc' 30ms -1 & param_bigger `get_beat_bar 8` 0.5 ? get_beat_bar 8 & param_multiply 0.6 & param_add 0.5 & param_cast & filter : get_beat_bar 8 & param_multiply -1 & param_add 1 & param_multiply 0.6 & param_add 0.5 & param_cast & filter
Side note
works but could also be expressed as
get_beat_bar 8 & param_invert &
32%
