I have gave up with I Tunes as using VDJ8 with ITunes is a pain. Is there another Music Player I could use with VDJ8 would Real Player or something similiar show up on my folders list.
Posted Wed 14 Dec 16 @ 9:37 am
You don't need a music player or anything else.
VDJ library management is the best in the business if you know how to use it properly. Nothing external needed.
Posted Wed 14 Dec 16 @ 10:54 am
I'm with Keith. VDJ is great for tagging your files once you get the hang of it. It is a little slower but worth it in the end.
What is it you are trying to do?? Let's start there and see if we can't help you out.
And yes iTunes is horrible.
Posted Wed 14 Dec 16 @ 4:14 pm
How do I export my filter folders to playlists (automatically) to be used in, uuhhhhh "another software"
lol
I use Music Bee btw
lol
I use Music Bee btw
Posted Wed 14 Dec 16 @ 7:28 pm
I'm sorry but your question has nothin g to do with this subject. Please do not hijack some else's thread, start your own, thank you.
Posted Wed 14 Dec 16 @ 7:46 pm
MEDIAMONKEY.
Period. Fidizuck Itunes.
I use it as a complete media library Manager, that also organizes my dj environment. I can then export that into vdj as an itunes export. I also have it on my desktop and laptop to keep them both in sync and updated, well with the help of FreeFileSync. I can surely help you get through it and pass on scripts that help the dj.
Posted Wed 14 Dec 16 @ 8:16 pm
Thanks Guys I use VDJ for all my folders the reason I was asking was I carry a small 2 channel mixer and a I Pod as back up and with windows 10 it is akward to run i tunes to keep the i pod up to date. Another small question for anyone who can help. How do I find out when I first installed VDJ on my laptop I am now on laptop #3 since first installed VDJ.
Posted Thu 15 Dec 16 @ 2:21 pm
Djratedxxx919 wrote :
MEDIAMONKEY.
I will give this a go cheers mate.
Posted Thu 15 Dec 16 @ 2:24 pm
im with kradcliffe!!!! i have fellow dj's in my town who use VDJ and hate serato like me... and they are always talking about man i hate itunes....im like vdj is folder based ? why even install extra stuff ? just make a folder as as upcoming event playlist...
Posted Fri 16 Dec 16 @ 2:34 am
I use advanced renamer [before even adding to vdj] to get my files named as so,
Artist - Title, feat. (Remix)
uses regex and for renaming an album at a time isn't that difficult (like 20 seconds to do an album)
that way even if the tags are wrong it's quick to parse [inside vdj] the basic tags from file name.
If you've got files already cue'd but miss tagged, and not the correct name for parsing tags, things to speed up tag editing
select all files in an album/ep ctrl+a, sort out the constants [album name, delete useless comments]
working on single files
alt+n (next file)
tab (tab down the text boxes)
shift+tab (tab up the text boxes)
alt+enter (ok)
once that's sorted you should be good to select all files of an album again and rename file Artist - Title (remix) from tag entries
I recently attacked my database xml with regex and np+, it's a bit risky as a newb (I made a couple of copies of the database every couple of regex passes and still messed up a few times)
also used my library plugin and my own filters to check stuff between regex passes [still got a couple of hundred files to drop track number off the start]
alt+n (next file)
alt+enter (ok)
Posted Fri 16 Dec 16 @ 6:45 am
I use tag&rename before importing in VDJ or itunes. Very easy to change the tags of a whole cd. After importing VDJ is very good for anything else...
Posted Fri 16 Dec 16 @ 3:22 pm
Agreed. I use MP3tag to tag the track and add art. After that everything else is managed from within VDJ.
Posted Fri 16 Dec 16 @ 3:36 pm
Do any of these alternatives do MP4's as well fellas??
I'm more concerned with video but I do have mp3's as well, lol!
Posted Fri 16 Dec 16 @ 3:44 pm
Most of my music is ripped from CD, using Exact Audio copy to rip in Flac codec. I use a GD3 plugin which cost £7 to import metadata. I can add other stuff at that point to. Everything else I add myself within VDJ, like ratings, colours, release year, decade etc. Other stuff is downloaded from Qobuz or Juno Download in high res and comes tagged. Would be great if VDJ could partner with a metadata company though so you could just press a button in the tag editor to search and populate.
Posted Fri 16 Dec 16 @ 4:06 pm
Huey,
MP3tag does MP4 perfectly as well. I tag all my videos exactly the same as the music files.
Posted Fri 16 Dec 16 @ 4:08 pm
Awesome Keith!!
Probably be hitting you up for some tips and tricks in the near future.
Posted Fri 16 Dec 16 @ 4:34 pm
cheers
Posted Fri 16 Dec 16 @ 9:06 pm
So how do you guys play music when your not djing.
Posted Fri 16 Dec 16 @ 10:38 pm
VDJ8 through the amp and speakers in the house.
Posted Fri 16 Dec 16 @ 10:52 pm
Yup, I just load up a playlist in VDJ's auto mix and then stream it wirelessly to Apple TV in any room I'm in.
Posted Sat 17 Dec 16 @ 12:29 am
