Hi, ich hatte im vms4 Stammtisch danach gefragt. Ob es beim denon auch geht kann ich dir natürlich nicht beantworten. Aber da es ja eigentlich eine VDJ Einstellung ist, denke ich schon.
Du musst in die vdj Einstellungen. Dann zum Controller menu.
Dort gibt es dann einen key, der oninit heißt..
Dort trägst du dass dann ein
Ich hab mir am Ende noch
Deck 3 select hinzugefügt. Das ist dann das Deck, das ausgewählt ist.
Vieles Spaß
Vieles Spaß
Posted Sat 17 Mar 18 @ 10:49 am
Empfohlene USB Driver für MCX 8000
SanDisk Extreme 500GB Portable SSD (Killer drives!!)
SanDisk Ultra USB 3.0 128GB
PNY Turbo Elite USB 3.0 32GB
Beta Build 005
Fixed issue where hotcues were not immediately written with the same track on both decks when loading from prepare list
Fixed issue where hotcue data is not stored correctly when loading track from prepare list
Removed Loop disable when triggering initial cue and hotcues
Fixed issue where Continuous mode didn’t work after reaching the end of list
Changed “Time Mode” setting in utility mode to reflect immediately
Fixed issue where Prepare list would sometimes show duplicate track/artist names
Fixed issue where microphones where cut off when switching between LN/Engine/PC
Beta Build 005
Posted Thu 22 Mar 18 @ 6:44 pm
Here is the latest beta build for your testing consumption. Today’s release brings further refinements and a couple of functional changes that just made sense. As always, thank you for your continued help!
Beta Build 006
Fixed issue where total time was not always updated
Fixed issue where Engine could crash when ejecting a USB while performance data was being saved
Fixed issue where some tracks would show the incorrect BPM value in track list
Fixed issue where some tracks would show the incorrect time in track list
Fixed issue where the loop region would disable after performing a loop jump
Fixed issue where the loop was sometimes disabled after triggering the loop
Fixed reloop issue that caused audio drop if triggered when no loop had previously been set
Improved sync drift when moving a loop region with parameter buttons
Improved sync drift during short loops
Removed preview stutter when using needle drop
Removed 0% pitch range
Added pitch range lock (soft takeover) to prevent drastic pitch jumps when moving the pitch fader at large pitch percentage ranges
Download - MCX8000 Beta v2.0 Build 006 - Link 1 19
Download - MCX8000 Beta v2.0 Build 006 - Link 2 6
Beta Build 006
Posted Thu 29 Mar 18 @ 4:35 pm
hier ein paar Einstellungen für die neue Firmware
Mic attenuation -10
Talk over level -6
USB output level setting 15db
Mic attenuation -10
Talk over level -6
Posted Tue 10 Apr 18 @ 4:57 pm
EXELBONSAI wrote :
installiert denn jemand die Beta`s ?
möchte wissen ob endlich (übrigens mein einzigstes Manko) der Audioausgang (der Interne) für Sound2light Plugins bzw auch die interne VDJ Aufnahme höher gepegelt ist?!
ja ist es mit dieser Einstellung USB output level setting 15db
Posted Tue 10 Apr 18 @ 5:00 pm
Hey Metrix, aber es ist noch immer eine BETA-Version richtig?
Gruß Lokke
Gruß Lokke
Posted Tue 10 Apr 18 @ 6:32 pm
Quote :
Gibts dafür jetzt extra eine Menüeinstellung ?
Cooooool. . . nice. . .
Danke
Posted Tue 10 Apr 18 @ 8:47 pm
ja hier die neueste Beta Build 007 die Firmware ist jetzt schon sehr stabil
We are really closing in on this release, thanks to you! Keep up the great work!
Fixed issue where performing a beat jump in Roll mode would move the playhead back 27 seconds rather than the specified loop size
Fixed issue where performing forward beat jump from pause state would sometimes start track playback
Fixed issue where triggering a hotcue to jump out of an active loop region caused the track to slow down and eventually stop
Fixed issue where loop move function was triggering 1/32 loop size on second press
Fixed issue that prevented tracks in the key of 8B to not be shown in list view
Changed “Auto Cue Level” to “Track Start Position”. Tracks will now load to the Initial Cue position or Track Start
Changed “Default Auto Loop Beat” setting name to “Default Auto Loop Size”
Expanded support for sorted folder names from 32 to 64 characters
Ja und viele weitere Einstellungen
Posted Thu 12 Apr 18 @ 5:00 pm
Habe jetzt 2 wichtige VA´s danach werde ich mir die neuste Beta auch mal antun. . . (neugier)
Posted Thu 12 Apr 18 @ 8:58 pm
Nabend zusammen.
Ich kann leider den link zum download des beta Firmware update nicht finden. Kann mir jemand helfen
Posted Mon 16 Apr 18 @ 7:06 pm
djmarcusm wrote :
Nabend zusammen.
http://denondjforum.com/t/invitation-to-the-mcx8000-firmware-2-0-public-beta-tests/8236
Posted Mon 16 Apr 18 @ 9:38 pm
Vielen Dank. Aber wo finde ich da den Download?
Posted Tue 17 Apr 18 @ 9:25 am
Sorry. Erst lesen dann schreiben.
Posted Tue 17 Apr 18 @ 9:26 am
Abend, bei mir frieren beide Displays ein. Egal ob über vdj, usb, oder Serato. Woran kann das liegen?
Posted Wed 18 Apr 18 @ 6:53 pm
Hardwaredefekt ?
Posted Thu 19 Apr 18 @ 7:35 am
djragman wrote :
Hardwaredefekt ?
Habe den MCX 8000 erst seid 2 Tagen. Das einfrieren tritt mal auf und mal nicht. Heute Morgen ist er 1 Std ohne Probleme gelaufen.
Posted Thu 19 Apr 18 @ 7:49 am
Auch mal überprüft ob die aktuellste Firmware drauf ist ?
Posted Thu 19 Apr 18 @ 8:56 am
ja habe die aktuelle firmware von der denon dj seite geladen und wollte sie aufspielen. da stand aber "up to date" Gehe davon aus das die aktuelle Firmware drauf ist.
Posted Thu 19 Apr 18 @ 8:59 am
Und der Controller ist neu oder gebraucht ?
Wenn Garantie ..weg damit würde auch sofort einen Hardwaredefekt vermuten.
Paar Ideen die ich noch prüfen würde.
Das richtige Netzteil?
Mal ein Reset gemacht ?
Eventuell noch die Audiofiles mal auf Auffälligkeiten überprüfen.
Testweise mal eine andere Steckdose verwenden nur für den Controller
Posted Thu 19 Apr 18 @ 10:08 am
Controller ist nagelneu vom Händler. Werde Ihn dann mal zurück senden.
Posted Thu 19 Apr 18 @ 10:13 am
