Forum: Old versions
Topic: Pioneer DDJ SX2 - Page: 3
Sound Good Thanks guys SX-2 is 3/4 there of being the Master controller for DJin.
Anyone have the cross fader working properly? The slide is not smooth, it goes from the extreme left to the middle to the extreme right.
Turned out to be a firmware issue. Flashed the firmware and it's now fine!
Good afternoon all, l've got a question about the DDJ-SX2. When you plug in the mic into channel 4 on my DDJ-SX2 is there any way to add Fx to the mic channel using the VDJ8 software? Any help would be gratefully appreciated. Thanks..
No, the mic inputs on channel 1 & 4 are hardware control and bypass VDJ
Is anyone else experiencing jumps when turning the gain knows? The position of the knobs on the screen and the knobs on the controller don't match up.
Hi Keith!
I am upgrading my setup to SX2 and VDJ8. Would you kindly post your laptop spec for your system.
My Dell M90 has been working perfectly for my MC6000 / VDJ7 combo but freezes with VDJ8.
(Your early postings addressing the Denon MC6000/VDJ audio failings had been very helpful, i.e., drop Denon ASIO; use WDM instead.)
I am getting the SX2; now, I need a more recent laptop for VDJ8.
(The M90's graphics card and VDJ8 do not go well with each other.)
Thanks, man!
A 13.3" screen with 3200 x 1800 pixels? Isn't everything microscopic? :-O
I have downscaled the display to 1920 x 1080 and it's perfect.
Windows looks like crap at full resolution (and most programs don't scale accordingly). Totally over the top to be honest!
Thanks Keith. I just pulled the trigger on the SX2 - great Cyber Monday deal!
Anyways, I am using a Dell D630 to run VDJ8 right now flawlessly, except for the 14" display.
I guess if just looking at the file browser, you really do not need a big display, huh?
Just got used to the 17" Dell Precision M90s for VDJ 7 and MC6000.
Thanks again.
Yes! I'm looking for a solution. Have you managed to find anything out yet? The mapping is 90% there, just needs tweaking. Might have to stick with my sx1 for a bit.
Nope, no solution. Some of the effects knobs are even further off than the gain knobs. Other than those things, it's a hell off a combination with vdj8.
Are you talking about the soft-takeover ? (when something changes on the screen and the hardware knob needs to "catch" that position in order to work again ?)
Nope. . Familiar with that. What I've noticed is a different thing. If my gain knobs are set at 12 o'clock, they are pretty much spot on and smooth until around 3 or 9. From there they jump to 0 or 100% any small adjustment past that has a larger affect on the screen.
I reported this previously and it is still an issue. Between the first part (lowest volume) aand 9 O clock going up and down is very jittery.
Can someone post here the data that those Gain knobs send when turning from 12 o clock to minimum ? Use Miditrace or MIDI OX
But really makes no sense to have such a behavior. Normally you should receive 00 at minimum position and 3F or 40 at 12 o clock and the data in between should be smooth (from 40 to 0) without big steps if you turn that slowly.
This is my 1st time doing this, so not sure if I did it right. I Tried 2 knobs, starting at 12 and turning them to their min.
B2 04 3C 00
B2 24 05 00
B2 04 3B 00
B2 24 67 00
B2 04 3B 00
B2 24 49 00
B2 04 3B 00
B2 24 2B 00
B2 04 3B 00
B2 24 0D 00
B2 04 3A 00
B2 24 70 00
B2 04 3A 00
B2 24 52 00
B2 04 3A 00
B2 24 34 00
B2 04 3A 00
B2 24 16 00
B2 04 39 00
B2 24 78 00
B2 04 39 00
B2 24 5A 00
B2 04 39 00
B2 24 3D 00
B2 04 39 00
B2 24 1F 00
B2 04 39 00
B2 24 01 00
B2 04 38 00
B2 24 63 00
B2 04 38 00
B2 24 45 00
B2 04 38 00
B2 24 28 00
B2 04 38 00
B2 24 0A 00
B2 04 37 00
B2 24 6C 00
B2 04 37 00
B2 24 4E 00
B2 04 37 00
B2 24 30 00
B2 04 37 00
B2 24 12 00
B2 04 36 00
B2 24 75 00
B2 04 36 00
B2 24 57 00
B2 04 36 00
B2 24 39 00
B2 04 36 00
B2 24 1B 00
B2 04 35 00
B2 24 7D 00
B2 04 35 00
B2 24 60 00
B2 04 35 00
B2 24 42 00
B2 04 35 00
B2 24 24 00
B2 04 35 00
B2 24 06 00
B2 04 34 00
B2 24 68 00
B2 04 34 00
B2 24 4A 00
B2 04 34 00
B2 24 2D 00
B2 04 34 00
B2 24 0F 00
B2 04 33 00
B2 24 71 00
B2 04 33 00
B2 24 53 00
B2 04 33 00
B2 24 35 00
B2 04 33 00
B2 24 18 00
B2 04 32 00
B2 24 77 00
B2 04 32 00
B2 24 57 00
B2 04 32 00
B2 24 37 00
B2 04 32 00
B2 24 17 00
B2 04 31 00
B2 24 77 00
B2 04 31 00
B2 24 57 00
B2 04 31 00
B2 24 37 00
B2 04 31 00
B2 24 17 00
B2 04 30 00
B2 24 76 00
B2 04 30 00
B2 24 56 00
B2 04 30 00
B2 24 36 00
B2 04 30 00
B2 24 16 00
B2 04 2F 00
B2 24 76 00
B2 04 2F 00
B2 24 56 00
B2 04 2F 00
B2 24 36 00
B2 04 2F 00
B2 24 16 00
B2 04 2E 00
B2 24 76 00
B2 04 2E 00
B2 24 55 00
B2 04 2E 00
B2 24 35 00
B2 04 2E 00
B2 24 15 00
B2 04 2D 00
B2 24 75 00
B2 04 2D 00
B2 24 55 00
B2 04 2D 00
B2 24 35 00
B2 04 2D 00
B2 24 15 00
B2 04 2C 00
B2 24 75 00
B2 04 2C 00
B2 24 54 00
B2 04 2C 00
B2 24 34 00
B2 04 2C 00
B2 24 14 00
B2 04 2B 00
B2 24 74 00
B2 04 2B 00
B2 24 54 00
B2 04 2B 00
B2 24 34 00
B2 04 2B 00
B2 24 14 00
B2 04 2A 00
B2 24 74 00
B2 04 2A 00
B2 24 54 00
B2 04 2A 00
B2 24 33 00
B2 04 2A 00
B2 24 13 00
B2 04 29 00
B2 24 73 00
B2 04 29 00
B2 24 53 00
B2 04 29 00
B2 24 33 00
B2 04 29 00
B2 24 13 00
B2 04 28 00
B2 24 73 00
B2 04 28 00
B2 24 53 00
B2 04 28 00
B2 24 32 00
B2 04 28 00
B2 24 12 00
B2 04 27 00
B2 24 72 00
B2 04 27 00
B2 24 52 00
B2 04 27 00
B2 24 32 00
B2 04 27 00
B2 24 12 00
B2 04 26 00
B2 24 72 00
B2 04 26 00
B2 24 52 00
B2 04 26 00
B2 24 32 00
B2 04 25 00
B2 24 7D 00
B2 04 25 00
B2 24 48 00
B2 04 25 00
B2 24 13 00
B2 04 24 00
B2 24 5E 00
B2 04 24 00
B2 24 29 00
B2 04 23 00
B2 24 74 00
B2 04 23 00
B2 24 40 00
B2 04 23 00
B2 24 0B 00
B2 04 22 00
B2 24 56 00
B2 04 22 00
B2 24 21 00
B2 04 21 00
B2 24 6C 00
B2 04 21 00
B2 24 37 00
B2 04 21 00
B2 24 03 00
B2 04 20 00
B2 24 4E 00
B2 04 20 00
B2 24 19 00
B2 04 1F 00
B2 24 64 00
B2 04 1F 00
B2 24 2F 00
B2 04 1E 00
B2 24 7A 00
B2 04 1E 00
B2 24 46 00
B2 04 1E 00
B2 24 11 00
B2 04 1D 00
B2 24 5C 00
B2 04 1D 00
B2 24 27 00
B2 04 1C 00
B2 24 72 00
B2 04 1C 00
B2 24 3D 00
B2 04 1C 00
B2 24 09 00
B2 04 1B 00
B2 24 54 00
B2 04 1B 00
B2 24 1F 00
B2 04 1A 00
B2 24 6A 00
B2 04 1A 00
B2 24 35 00
B2 04 1A 00
B2 24 00 00
B2 04 19 00
B2 24 4C 00
B2 04 18 00
B2 24 65 00
B2 04 17 00
B2 24 7F 00
B2 04 17 00
B2 24 18 00
B2 04 16 00
B2 24 32 00
B2 04 15 00
B2 24 4C 00
B2 04 14 00
B2 24 65 00
B2 04 13 00
B2 24 7F 00
B2 04 13 00
B2 24 19 00
B2 04 12 00
B2 24 32 00
B2 04 11 00
B2 24 4C 00
B2 04 10 00
B2 24 65 00
B2 04 0F 00
B2 24 7F 00
B2 04 0F 00
B2 24 19 00
B2 04 0E 00
B2 24 32 00
B2 04 0D 00
B2 24 4C 00
B2 04 0C 00
B2 24 66 00
B2 04 0A 00
B2 24 7C 00
B2 04 09 00
B2 24 12 00
B2 04 07 00
B2 24 28 00
B2 04 05 00
B2 24 3E 00
B2 04 00 00
B2 24 00 00
B0 04 3E 00
B0 24 4E 00
B0 04 3E 00
B0 24 41 00
B0 04 3D 00
B0 24 68 00
B0 04 3D 00
B0 24 5B 00
B0 04 3D 00
B0 24 4E 00
B0 04 3D 00
B0 24 42 00
B0 04 3D 00
B0 24 35 00
B0 04 3C 00
B0 24 5C 00
B0 04 3C 00
B0 24 4F 00
B0 04 3C 00
B0 24 43 00
B0 04 3C 00
B0 24 36 00
B0 04 3B 00
B0 24 50 00
B0 04 3B 00
B0 24 43 00
B0 04 3B 00
B0 24 37 00
B0 04 3B 00
B0 24 2A 00
B0 04 3B 00
B0 24 1D 00
B0 04 3B 00
B0 24 11 00
B0 04 3B 00
B0 24 04 00
B0 04 3A 00
B0 24 77 00
B0 04 3A 00
B0 24 6A 00
B0 04 3A 00
B0 24 5E 00
B0 04 3A 00
B0 24 51 00
B0 04 3A 00
B0 24 44 00
B0 04 3A 00
B0 24 38 00
B0 04 3A 00
B0 24 2B 00
B0 04 3A 00
B0 24 1E 00
B0 04 3A 00
B0 24 11 00
B0 04 3A 00
B0 24 05 00
B0 04 39 00
B0 24 78 00
B0 04 39 00
B0 24 6B 00
B0 04 39 00
B0 24 5F 00
B0 04 39 00
B0 24 52 00
B0 04 39 00
B0 24 45 00
B0 04 39 00
B0 24 38 00
B0 04 39 00
B0 24 2C 00
B0 04 39 00
B0 24 1F 00
B0 04 38 00
B0 24 46 00
B0 04 38 00
B0 24 39 00
B0 04 38 00
B0 24 2D 00
B0 04 37 00
B0 24 54 00
B0 04 37 00
B0 24 47 00
B0 04 37 00
B0 24 3A 00
B0 04 37 00
B0 24 2D 00
B0 04 37 00
B0 24 21 00
B0 04 36 00
B0 24 48 00
B0 04 36 00
B0 24 3B 00
B0 04 36 00
B0 24 2E 00
B0 04 35 00
B0 24 55 00
B0 04 35 00
B0 24 49 00
B0 04 35 00
B0 24 3C 00
B0 04 35 00
B0 24 2F 00
B0 04 35 00
B0 24 22 00
B0 04 35 00
B0 24 16 00
B0 04 35 00
B0 24 09 00
B0 04 34 00
B0 24 7C 00
B0 04 34 00
B0 24 70 00
B0 04 34 00
B0 24 63 00
B0 04 34 00
B0 24 56 00
B0 04 34 00
B0 24 49 00
B0 04 34 00
B0 24 3D 00
B0 04 34 00
B0 24 30 00
B0 04 33 00
B0 24 57 00
B0 04 33 00
B0 24 4A 00
B0 04 33 00
B0 24 3E 00
B0 04 33 00
B0 24 31 00
B0 04 33 00
B0 24 24 00
B0 04 33 00
B0 24 18 00
B0 04 33 00
B0 24 0B 00
B0 04 32 00
B0 24 7E 00
B0 04 32 00
B0 24 23 00
B0 04 32 00
B0 24 16 00
B0 04 32 00
B0 24 09 00
B0 04 31 00
B0 24 7C 00
B0 04 31 00
B0 24 6F 00
B0 04 31 00
B0 24 62 00
B0 04 31 00
B0 24 07 00
B0 04 30 00
B0 24 7A 00
B0 04 30 00
B0 24 6D 00
B0 04 30 00
B0 24 12 00
B0 04 30 00
B0 24 05 00
B0 04 2F 00
B0 24 2A 00
B0 04 2F 00
B0 24 1D 00
B0 04 2F 00
B0 24 10 00
B0 04 2F 00
B0 24 03 00
B0 04 2E 00
B0 24 76 00
B0 04 2E 00
B0 24 69 00
B0 04 2E 00
B0 24 5C 00
B0 04 2E 00
B0 24 4F 00
B0 04 2D 00
B0 24 67 00
B0 04 2D 00
B0 24 5A 00
B0 04 2D 00
B0 24 4D 00
B0 04 2D 00
B0 24 33 00
B0 04 2D 00
B0 24 26 00
B0 04 2D 00
B0 24 19 00
B0 04 2D 00
B0 24 0C 00
B0 04 2C 00
B0 24 7F 00
B0 04 2C 00
B0 24 72 00
B0 04 2C 00
B0 24 65 00
B0 04 2C 00
B0 24 58 00
B0 04 2C 00
B0 24 4B 00
B0 04 2C 00
B0 24 3E 00
B0 04 2C 00
B0 24 31 00
B0 04 2C 00
B0 24 24 00
B0 04 2C 00
B0 24 17 00
B0 04 2C 00
B0 24 0A 00
B0 04 2B 00
B0 24 7D 00
B0 04 2B 00
B0 24 70 00
B0 04 2B 00
B0 24 63 00
B0 04 2B 00
B0 24 56 00
B0 04 2B 00
B0 24 49 00
B0 04 2B 00
B0 24 3C 00
B0 04 2B 00
B0 24 2F 00
B0 04 2B 00
B0 24 22 00
B0 04 2B 00
B0 24 15 00
B0 04 2B 00
B0 24 08 00
B0 04 2A 00
B0 24 7B 00
B0 04 2A 00
B0 24 6E 00
B0 04 2A 00
B0 24 61 00
B0 04 2A 00
B0 24 54 00
B0 04 2A 00
B0 24 47 00
B0 04 2A 00
B0 24 3A 00
B0 04 2A 00
B0 24 2D 00
B0 04 2A 00
B0 24 20 00
B0 04 2A 00
B0 24 13 00
B0 04 2A 00
B0 24 06 00
B0 04 29 00
B0 24 79 00
B0 04 29 00
B0 24 6C 00
B0 04 29 00
B0 24 5F 00
B0 04 29 00
B0 24 52 00
B0 04 29 00
B0 24 45 00
B0 04 29 00
B0 24 38 00
B0 04 29 00
B0 24 2B 00
B0 04 29 00
B0 24 1E 00
B0 04 29 00
B0 24 11 00
B0 04 29 00
B0 24 04 00
B0 04 28 00
B0 24 77 00
B0 04 28 00
B0 24 6A 00
B0 04 28 00
B0 24 5D 00
B0 04 28 00
B0 24 50 00
B0 04 28 00
B0 24 43 00
B0 04 28 00
B0 24 36 00
B0 04 28 00
B0 24 29 00
B0 04 28 00
B0 24 1C 00
B0 04 28 00
B0 24 0F 00
B0 04 28 00
B0 24 02 00
B0 04 27 00
B0 24 75 00
B0 04 27 00
B0 24 68 00
B0 04 27 00
B0 24 5B 00
B0 04 27 00
B0 24 4E 00
B0 04 27 00
B0 24 41 00
B0 04 27 00
B0 24 34 00
B0 04 27 00
B0 24 27 00
B0 04 27 00
B0 24 1A 00
B0 04 27 00
B0 24 0D 00
B0 04 27 00
B0 24 00 00
B0 04 26 00
B0 24 73 00
B0 04 26 00
B0 24 66 00
B0 04 26 00
B0 24 59 00
B0 04 26 00
B0 24 4C 00
B0 04 26 00
B0 24 3F 00
B0 04 26 00
B0 24 32 00
B0 04 26 00
B0 24 23 00
B0 04 26 00
B0 24 15 00
B0 04 26 00
B0 24 06 00
B0 04 25 00
B0 24 78 00
B0 04 25 00
B0 24 6A 00
B0 04 25 00
B0 24 5B 00
B0 04 25 00
B0 24 4D 00
B0 04 25 00
B0 24 3F 00
B0 04 25 00
B0 24 30 00
B0 04 25 00
B0 24 22 00
B0 04 25 00
B0 24 13 00
B0 04 25 00
B0 24 05 00
B0 04 24 00
B0 24 77 00
B0 04 24 00
B0 24 68 00
B0 04 24 00
B0 24 5A 00
B0 04 24 00
B0 24 4C 00
B0 04 24 00
B0 24 3D 00
B0 04 24 00
B0 24 2F 00
B0 04 24 00
B0 24 21 00
B0 04 24 00
B0 24 12 00
B0 04 24 00
B0 24 04 00
B0 04 23 00
B0 24 75 00
B0 04 23 00
B0 24 11 00
B0 04 23 00
B0 24 02 00
B0 04 22 00
B0 24 74 00
B0 04 22 00
B0 24 66 00
B0 04 22 00
B0 24 57 00
B0 04 22 00
B0 24 49 00
B0 04 22 00
B0 24 3B 00
B0 04 22 00
B0 24 2C 00
B0 04 22 00
B0 24 1E 00
B0 04 22 00
B0 24 10 00
B0 04 22 00
B0 24 01 00
B0 04 21 00
B0 24 73 00
B0 04 21 00
B0 24 64 00
B0 04 21 00
B0 24 56 00
B0 04 21 00
B0 24 48 00
B0 04 21 00
B0 24 39 00
B0 04 21 00
B0 24 2B 00
B0 04 21 00
B0 24 1D 00
B0 04 21 00
B0 24 0E 00
B0 04 21 00
B0 24 00 00
B0 04 20 00
B0 24 71 00
B0 04 20 00
B0 24 63 00
B0 04 20 00
B0 24 55 00
B0 04 20 00
B0 24 46 00
B0 04 20 00
B0 24 38 00
B0 04 20 00
B0 24 2A 00
B0 04 20 00
B0 24 1B 00
B0 04 20 00
B0 24 0D 00
B0 04 1F 00
B0 24 7F 00
B0 04 1F 00
B0 24 70 00
B0 04 1F 00
B0 24 62 00
B0 04 1F 00
B0 24 53 00
B0 04 1F 00
B0 24 45 00
B0 04 1F 00
B0 24 37 00
B0 04 1F 00
B0 24 28 00
B0 04 1F 00
B0 24 1A 00
B0 04 1F 00
B0 24 0C 00
B0 04 1E 00
B0 24 7D 00
B0 04 1E 00
B0 24 6F 00
B0 04 1E 00
B0 24 60 00
B0 04 1E 00
B0 24 52 00
B0 04 1D 00
B0 24 5F 00
B0 04 1D 00
B0 24 51 00
B0 04 1D 00
B0 24 42 00
B0 04 1D 00
B0 24 34 00
B0 04 1D 00
B0 24 26 00
B0 04 1D 00
B0 24 17 00
B0 04 1D 00
B0 24 09 00
B0 04 1C 00
B0 24 7B 00
B0 04 1C 00
B0 24 6C 00
B0 04 1C 00
B0 24 5E 00
B0 04 1C 00
B0 24 4F 00
B0 04 1C 00
B0 24 41 00
B0 04 1C 00
B0 24 33 00
B0 04 1C 00
B0 24 24 00
B0 04 1C 00
B0 24 16 00
B0 04 1C 00
B0 24 08 00
B0 04 1B 00
B0 24 79 00
B0 04 1B 00
B0 24 6B 00
B0 04 1B 00
B0 24 5D 00
B0 04 1B 00
B0 24 4E 00
B0 04 1B 00
B0 24 40 00
B0 04 1B 00
B0 24 31 00
B0 04 1B 00
B0 24 23 00
B0 04 1B 00
B0 24 15 00
B0 04 1B 00
B0 24 06 00
B0 04 1A 00
B0 24 78 00
B0 04 1A 00
B0 24 6A 00
B0 04 1A 00
B0 24 5B 00
B0 04 1A 00
B0 24 4D 00
B0 04 1A 00
B0 24 3E 00
B0 04 1A 00
B0 24 30 00
B0 04 1A 00
B0 24 22 00
B0 04 1A 00
B0 24 13 00
B0 04 1A 00
B0 24 05 00
B0 04 19 00
B0 24 77 00
B0 04 19 00
B0 24 68 00
B0 04 19 00
B0 24 5A 00
B0 04 19 00
B0 24 4C 00
B0 04 19 00
B0 24 3A 00
B0 04 19 00
B0 24 29 00
B0 04 19 00
B0 24 17 00
B0 04 19 00
B0 24 06 00
B0 04 18 00
B0 24 74 00
B0 04 18 00
B0 24 63 00
B0 04 18 00
B0 24 52 00
B0 04 18 00
B0 24 40 00
B0 04 18 00
B0 24 2F 00
B0 04 18 00
B0 24 1D 00
B0 04 18 00
B0 24 0C 00
B0 04 17 00
B0 24 7A 00
B0 04 17 00
B0 24 69 00
B0 04 17 00
B0 24 58 00
B0 04 17 00
B0 24 46 00
B0 04 17 00
B0 24 35 00
B0 04 17 00
B0 24 23 00
B0 04 17 00
B0 24 12 00
B0 04 17 00
B0 24 00 00
B0 04 16 00
B0 24 6F 00
B0 04 16 00
B0 24 5E 00
B0 04 16 00
B0 24 4C 00
B0 04 16 00
B0 24 3B 00
B0 04 16 00
B0 24 29 00
B0 04 16 00
B0 24 18 00
B0 04 16 00
B0 24 06 00
B0 04 15 00
B0 24 75 00
B0 04 15 00
B0 24 64 00
B0 04 15 00
B0 24 52 00
B0 04 15 00
B0 24 41 00
B0 04 15 00
B0 24 2F 00
B0 04 15 00
B0 24 1E 00
B0 04 15 00
B0 24 0C 00
B0 04 14 00
B0 24 7B 00
B0 04 14 00
B0 24 6A 00
B0 04 14 00
B0 24 58 00
B0 04 14 00
B0 24 47 00
B0 04 14 00
B0 24 35 00
B0 04 14 00
B0 24 24 00
B0 04 14 00
B0 24 12 00
B0 04 14 00
B0 24 01 00
B0 04 13 00
B0 24 70 00
B0 04 13 00
B0 24 5E 00
B0 04 13 00
B0 24 4D 00
B0 04 13 00
B0 24 3B 00
B0 04 13 00
B0 24 2A 00
B0 04 13 00
B0 24 19 00
B0 04 13 00
B0 24 07 00
B0 04 12 00
B0 24 76 00
B0 04 12 00
B0 24 64 00
B0 04 12 00
B0 24 53 00
B0 04 12 00
B0 24 41 00
B0 04 12 00
B0 24 30 00
B0 04 12 00
B0 24 1F 00
B0 04 12 00
B0 24 0D 00
B0 04 11 00
B0 24 7C 00
B0 04 11 00
B0 24 6A 00
B0 04 11 00
B0 24 59 00
B0 04 11 00
B0 24 47 00
B0 04 11 00
B0 24 36 00
B0 04 11 00
B0 24 25 00
B0 04 11 00
B0 24 13 00
B0 04 11 00
B0 24 02 00
B0 04 10 00
B0 24 70 00
B0 04 10 00
B0 24 5F 00
B0 04 10 00
B0 24 4D 00
B0 04 10 00
B0 24 3C 00
B0 04 10 00
B0 24 2B 00
B0 04 10 00
B0 24 19 00
B0 04 10 00
B0 24 08 00
B0 04 0F 00
B0 24 76 00
B0 04 0F 00
B0 24 65 00
B0 04 0F 00
B0 24 53 00
B0 04 0F 00
B0 24 42 00
B0 04 0F 00
B0 24 31 00
B0 04 0F 00
B0 24 1F 00
B0 04 0F 00
B0 24 0E 00
B0 04 0E 00
B0 24 7C 00
B0 04 0E 00
B0 24 6B 00
B0 04 0E 00
B0 24 59 00
B0 04 0E 00
B0 24 48 00
B0 04 0E 00
B0 24 37 00
B0 04 0E 00
B0 24 25 00
B0 04 0E 00
B0 24 14 00
B0 04 0E 00
B0 24 02 00
B0 04 0D 00
B0 24 71 00
B0 04 0D 00
B0 24 5F 00
B0 04 0D 00
B0 24 4E 00
B0 04 0D 00
B0 24 3D 00
B0 04 0D 00
B0 24 2B 00
B0 04 0D 00
B0 24 1A 00
B0 04 0D 00
B0 24 08 00
B0 04 0C 00
B0 24 77 00
B0 04 0C 00
B0 24 66 00
B0 04 0B 00
B0 24 78 00
B0 04 0B 00
B0 24 0B 00
B0 04 0A 00
B0 24 1E 00
B0 04 09 00
B0 24 31 00
B0 04 08 00
B0 24 44 00
B0 04 07 00
B0 24 56 00
B0 04 06 00
B0 24 69 00
B0 04 05 00
B0 24 7C 00
B0 04 05 00
B0 24 0F 00
B0 04 04 00
B0 24 22 00
B0 04 03 00
B0 24 34 00
B0 04 02 00
B0 24 47 00
B0 04 00 00
B0 24 00 00
Let me know if I need to try it again.
I've also noticed that when I turn the gains to the right, the knobs stops turning well before the software reaches it's max value.
Djdad.
Moving the knob from 12 to 0 position is not only 3F to 00 but 'rolls under', ie., 3C to 00 to 3C (2nd byte every other line).
Of course, at 3 or 9 positions, the absolute position will snap back to 12 (or 100%) at the point the data rolls under 00 to 3F (or 3C).
So, if the premise is that the quantization from 12 to 0 position is from 00 to 3F only (40 hex), then it is wrong!
Need to parse the 4th byte. When it rolls under, bit 1 changes from B2 to B0 to make it the encoding correct.
Just my 2 cents.
21%
