Forum: Old versions
Topic: Pioneer DDJ SX2 - Page: 15
Sorry, I can't remember. I sold the SX2 some time ago and went back to the MC6000 and SP1. Neither have coloured pads.
HI guys, I love my DDJ-SX2 to bits but it keeps freezing on me. Has anyone else experienced this? the software works fine but i loose total control of the decks, fader; everything. i end up having to switch it OFF and ON (which is the last thing you want to do mid-set)... Is there a setting or config i haven't done or is my console faulty? i also have the latest Firmware from Pioneer.
I Use Mac
13.3-inch (diagonal) LED-backlit glossy widescreen display, 1280-by-800 resolution
16GB (8 x 2GB) of 1600MHz DDR3 SDRAM
500GB Serial ATA @ 5400 rpm1
8x double-layer SuperDrive (DVD±R DL/DVD±RW/CD-RW)
Intel HD Graphics 4000
Please need Help
I have the exact same issue as mentioned above, SX stops responding but VDJ carries on.
Running MacBook Pro 2012, OSX Sierra, 16gb Ram, around 500GB spare on HD. Running nothing except Virtual DJ 8, Wifi turned off. Using Neo Oyaide USB cable.
Any help with this would be much appreciated
Is this random or happens frequently ?
For now i can only advise to make sure the Pioneer sound card is not the default audio device for the Operating system (from Audio Midi Setup - select the computer's builtin as default)
Its also advised to optimize your Mac for best performance http://www.virtualdj.com/wiki/Mac%20Optimize.html
