Can I map a jogwheel with Generic Mapping? I am trying to map a with touchwheel command but I have no chance. I am sure that I am trying to map the right midi signal as I am not touching the jog from above.
Cheers
Cheers
Posted Sat 26 Apr 14 @ 2:40 pm
Please see: https://virtualdj.com/wiki/How%20do%20I%20map%20my%20MIDI%20controller.html
You can't map (properly) a jog with SIMPLE MIDI.
Assuming that you are trying to map a new device that's not natively supported already there's a good chance the jog sends multiple different values when you rotate it. (Especially if this is a Pioneer unit)
Posted Sun 27 Apr 14 @ 11:04 am
