How do I map Virtual DJ with Gemini FIRSTMIX I/O? I've tried but it's not working. Please help.
Posted Sat 25 Jan 14 @ 12:20 pm
To map any controller you will need to have a Professional Edition license.
If you have one then the best thing to do is to register your serial number here: https://virtualdj.com/users/edit.html
Then download the mapper here: https://virtualdj.com/addons/14338/Gemini_FirstMix.html
Posted Sat 25 Jan 14 @ 12:25 pm
There's no need to download any mappers because the Gemini Firstmix is natively supported in the latest version of VirtualDJ v7.4.1 Pro.
Simply register your Pro serial number as above and then download the latest version from the Download Center.
Posted Sat 25 Jan 14 @ 12:27 pm
Hi,
I have first mix I/0 mixer but its not being recognised when I try to map it to virtual DJ8
I have downloaded and ran the installation of the mapping from the link you supplied but its still not recognising my controller. What else can I do?
It appears that the mapping files are saved as XML documents, could this affect it?
Posted Sat 22 Oct 16 @ 7:50 am
tengo un controlador gemini firsmix i/o necesito mapearlo para virutal 8.2
Posted Mon 23 Apr 18 @ 3:17 pm
Este es in foro de habla Inglesa solo, por favor prueba este foro, gracias.
Posted Mon 23 Apr 18 @ 8:29 pm
