You set up the ad-hoc network from your PC or Mac then the android device sees it as any other wifi connection. Nothing special required, I do it all the time.
Keith
Keith
Posted Mon 22 Jul 13 @ 7:41 am
PhantomDeejay wrote :
I'm doing this for Android. However Touch OSC is also available for iOS as well. So, there's a very good chance you can get this on iOS aw well :) (But I'll have to check this since I'm using a 'custom' screen size)
djshooter26 wrote :
only android or will be a chance to get it for ios when its ready :)
oh please test it :) i want it now now now now ;D <3
Posted Mon 22 Jul 13 @ 9:02 am
kradcliffe wrote :
You set up the ad-hoc network from your PC or Mac then the android device, sees it as any other wifi connection. Nothing special required, I do it all the time.
Keith
Keith
3 different phones and 2 tablets all see the network but won't connect. I'm using 4.1.1 Jellybean. I did a search and this is a known problem. With a router in place it works fine, without the router it sees the Ad Hoc but won't connect.
Here ya go, http://mobile.pcadvisor.co.uk/how-to/google-android/3372947/connect-android-phone-ad-hoc-network/
I can pull up hundreds of these threads, it won't work unless you root the phone/tablet with a certain rom.
Posted Mon 22 Jul 13 @ 9:54 am
Try CONNECTIFY if you're using PC. Quickest solution for all my wifi connection needs.
Posted Mon 22 Jul 13 @ 11:43 am
Unfortunately I'm on a Mac. Thanks for the info though.
Posted Mon 22 Jul 13 @ 12:10 pm
That's what I love about Windows. Things just work.
The six months I spent with a MacBook Pro was like having an arm missing!
Posted Mon 22 Jul 13 @ 1:45 pm
So then it doesn't work for you either?? At least on the Mac side it doesnt and don't turn this into a Mac vs PC thing cause it's not. It's more like Google vs Ad Hoc...... come on Keith.
Like I said I'll just have to carry around a spare router which isn't that big of a deal......
Posted Mon 22 Jul 13 @ 1:54 pm
Just winding you up Huey :)
Posted Mon 22 Jul 13 @ 1:56 pm
Yeah I know, just the thought of buying an iPad gave me the shivers when I can spend 100 bucks on an Android tablet and do the same thing , lol!!
Posted Mon 22 Jul 13 @ 2:08 pm
Well I would never have another one. I bought the 64gb 3G one when it came out for £700 and just 2 years later it's rendered obsolete. No update to iOS and now I can't update apps or install many new ones as they require the latest OS.
99% of Android devices have unlocked bootloaders and custom roms available that avoid that situation.
Apple no more for me!
Posted Mon 22 Jul 13 @ 2:23 pm
Might have found a solution for this little problem, I'll post here if it works as others may run into this as well.
Posted Tue 23 Jul 13 @ 8:38 am
Well I'm back, I didn't get the tablet rooted so I still can't use an Ad Hoc network BUT when I use my tablet as a mobile hotspot and connect the Mac to the tablet everything is a go!! Just have to manually type in the ip address but that s not a big deal. So there you go problem solved......
Posted Sat 27 Jul 13 @ 2:06 pm
I have similar problems regarding the ad-hoc network.
If I set up a network with my iPhone my tablet connects immediatly but if I set up a network with my MacBook Air the Samsung Galaxy Note will neither find the network nor connect to it even though SSID is published and I manually add it to my network list.
Result: I added a wlan router :D
Posted Sat 27 Jul 13 @ 4:12 pm
Try using your tablet as a hotspot and have your Mac connect to the tablet.
I was prepared to carry around an extra router but this way seems to be working well. I run some more test and report back.
Posted Sat 27 Jul 13 @ 4:40 pm
Just bumping this up as a lot of us don't or won't pay for an iPad, lol!! Anything happening with your template Phantom?? I could probably set up my own but if you have one made id love to try it Please........
Posted Wed 11 Dec 13 @ 2:18 pm
Any news on this, just stubled onto the thread which seemed really positive but then dies off in July 2013.
Phantom, any updates, need anything from us lot?
Posted Mon 16 Dec 13 @ 9:53 am
I have all the files available, but I have stopped developing the project because I gave away the tablet to my nephew.
I will try to "finish" some parts of the code that I had left under development and upload it on the next week.
Thanks!
Thanks!
Posted Tue 17 Dec 13 @ 2:43 am
That would be brilliant, thanks.
Posted Tue 17 Dec 13 @ 2:53 am
Phantom, sorry to push this but any chance of the release you mentioned.
Thanks
Thanks
Posted Fri 27 Dec 13 @ 4:55 pm
Thanks!
Thanks!
Phantom, Any update on this... please!
Posted Thu 16 Jan 14 @ 3:30 pm
