I can't wait =)
Posted Thu 18 Jul 13 @ 1:13 am
OK in anticipation of this I put OSC back on my phone (paid version) but I don't know how to connect it to a Mac. When I first bought it I had the same problem with a PC, so Please can someone explain this process??
Posted Thu 18 Jul 13 @ 10:36 am
You need to go to www.hexler.net and download the "Touch OSC Bridge" software (free) for your platform...
Posted Thu 18 Jul 13 @ 10:41 am
Hmm, I have it installed but nothing shows up on my phone when it's looking to connect. I can't find any tutorial s on there website either.
Posted Thu 18 Jul 13 @ 11:14 am
On the tablet side set the IP of your host manually...
It should be able to communicate then despite it doesn't find any hosts...
Posted Thu 18 Jul 13 @ 1:01 pm
Yeah that's what I had to do. I found a Resolume template and got it working on the OSC but now I gotta figure out the MIDI portion. When I look under the map tab in VDJ nothing shows up. I'm gonna assume I need some sort of MIDI translator??
Posted Thu 18 Jul 13 @ 2:47 pm
No, you need to create a device definition file and a mapper...
That's what I'm doing at the moment ;)
Posted Thu 18 Jul 13 @ 4:05 pm
I have a Nexus 7 if you need a tester. :-)
Posted Thu 18 Jul 13 @ 4:42 pm
I had my hands full also with this project almost 2 years ago. TouchOSC is very good and quite easy to deal with. And its absolutely functioning so well!
Posted Thu 18 Jul 13 @ 4:53 pm
Wow! Nice work!
Posted Thu 18 Jul 13 @ 8:24 pm
@Phantom, what tablet are you using?? It doesn't look like my Fire is gonna work without some sort of hack or sidelining.
Posted Thu 18 Jul 13 @ 9:53 pm
Samsung Galaxy Tab 2 10.1
Posted Fri 19 Jul 13 @ 1:51 am
this is looking great.
what are your plans for letting it lose, app store? purchase ?
good luck with your work,
Regards
Regards
Posted Fri 19 Jul 13 @ 5:46 am
Even though it's a little bit early for a release I want to clear up something:
What you see consists of 3 elements:
1) The Touch OSC application which is available as a purchase on Google Play. YOU WILL have to pay for that... (It's 4.5 euros = $6)
2) The Touch OSC Layout file
3) The VirtualDj Device definition and Mapper files
Once it's ready you will be able to get items 2 & 3 from the downloads section on this site via the usual route, AKA FOR FREE.
However you will have to purchase item 1 as I said above. This is beyond my control since I'm not the developer of Touch OSC ;)
Posted Fri 19 Jul 13 @ 5:55 am
Thanks, now I'm off to find one, lol!!
Posted Fri 19 Jul 13 @ 9:57 am
Transport page is ready... ;)
Posted Fri 19 Jul 13 @ 12:39 pm
only android or will be a chance to get it for ios when its ready :)
Posted Sun 21 Jul 13 @ 1:01 pm
GadgetMan wrote :
Liking a lot. If you're collecting names for testing, add me to the list please ;-)
Cheers,
Roy
Cheers,
Roy
I agree! It's so simple. I love it!
Posted Sun 21 Jul 13 @ 1:31 pm
I'm doing this for Android. However Touch OSC is also available for iOS as well. So, there's a very good chance you can get this on iOS aw well :) (But I'll have to check this since I'm using a 'custom' screen size)
Posted Mon 22 Jul 13 @ 12:25 am
Well I have been messing around with my Resolume template and got things how I want them. So I was setting up an "ad hoc" network only to find out that Android devices (tablets/phones) aren't compatible with them. From what I've read, you'll have to root and use a certain rom. This really sucks. Looks lime we'll always have to carry around a router.
Anybody got an ideas around this??
Posted Mon 22 Jul 13 @ 6:59 am
