Topic: Virtual DJ LE - Download - Page: 2
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of https://virtualdj.com/forums to post in your own language.
hola a todos tengo un numark mixdeck el cual vino con el virtual dj 5
podria descargar e instalar el virtual dj le
As already posted above, this forum is for English language messages only.
Please post your message in English or use the appropriate language forum at the bottom of https://virtualdj.com/forums to post in your own language.
NOTE: The MixDeck won't work with VirtualDJ v5. It's far too old to support this controller. You will need to upgrade to the latest VirtualDJ v7.4 Pro: https://virtualdj.com/buy/ - If you like VirtualDJ, then please support the software and its future development (Especially if you are a working DJ and you are making money as a result of using it at your gigs.)
hi i got a pioneer ddj wego and i have a windows 8 laptop i tried to download the new update but it doesnt seem to work and also i put the software cd into my laptop and every time i put in my serial number it doesnt work also on the website so what am i supposed to do please help me as soon as possible
comprei uma pioneer dj wego, veio com serial na versao trial, so vale 20 dias e so funciona 30 minutos. como faço para ativar ja que o produto e eriginal?
Hello friends. I bought mxr14 but I can't use it with the virtual dj softwear try to upgrade still not working pls any solution let someone help me out
tengo un dj ergo y me hace falta el software virtual dj LE yo tengo una menbresia con ustedes mensual será posible que me pudieran ayudar con el software
You should probably start your own thread instead of hijacking this one. What do you mean it's not working? Have you installed the latest pro version of VDJ?
Boa tarde comprei uma hercules dj control mp3 le,mas eu perdi o meu cd de instalaçao do virtual dj e nele estava incluso os drivers e para ajudar nessa semana que passou o meu notbook faz backup e apagou todos os programas.
Imploro a ajuda de alguem!
Obrigado
Can i buy only a serial number to Virtual DJ LE to mac, if I have thrown away my old serial number i got..
What can i do?
If you contact the manufacturer then they should be able to retrieve the VirtualDJ LE serial number from their records in most cases if you provide them with the hardware serial number of the controller itself: https://virtualdj.com/forums/151663/General_Discussion/Lost_Serials_-_VirtualDJ_LE_or_any_other_version.html
For further information and assistance, please contact support: https://virtualdj.com/contact/
NOTE: You should always keep serial numbers for any software products that you purchase in a safe place.
Hello. I just got an Pioneer DDJ WEGO2. In the box i got the Instalation disch for Virtual DJ Limited Edition.
I have a Macbook Air and I cant use the CD-disc. How do i get the software so i Can use my controller?
Is it possible to get the software without the CD?
I just purchased a DJ-WeGO2 I want to use it with my iPad how do I do that?
my name is dj don general i bought mxr mixer...i lost my virtual dj software...how can i get another soft ware.so that my mxr can be working...thanks...i need reply..
28%
