Ok, here is what my machine does...
- WiFi on
- real time mp3 recording from mixer tape out
- creating lightscribe cd label
- searching utoob for a couple's request
- editing an mp3 in audacity
- oh, and vdj playing in the background w/o as much a hiccup or burp.
At the same time. Now to be fair, I don't use timecodes or vinyl, but for the properly tuned rig, you should have no issues.
- WiFi on
Posted Thu 04 Oct 12 @ 7:26 am
Sonido Alto Voltaje wrote :
Does any body know if the loop bug was addressed?
still a bug
Posted Thu 04 Oct 12 @ 7:40 am
So is there colored wave forms in the 7.1 update??
Completely compatible with Lion/Mountain Lion??
Anyone know. I have not updated yet...
Posted Thu 04 Oct 12 @ 9:58 am
Everybody know. Take a look:
http://www.virtualdj.com/wiki/VirtualDJv7.1.html
Greets
Posted Thu 04 Oct 12 @ 10:01 am
No, it never made it to the final build.
Keith
Posted Thu 04 Oct 12 @ 10:05 am
VirtualDJ runs with no issues under the latest OSX.
Posted Thu 04 Oct 12 @ 10:22 am
Eh...guess I'll just wait....I was hoping colored wave forms would make it to the update. 7.05 works for what I use it for right now. If it ain't broke, don't fix it. :D
Posted Thu 04 Oct 12 @ 10:28 am
any chance that the L.E version users get this update ?
Posted Thu 04 Oct 12 @ 10:29 am
Depends which version of LE your console came with and whether the manufacturer approves it.
Keith
Posted Thu 04 Oct 12 @ 10:33 am
what is the ID3 tags update??
In what way was it broken?
As i dont use netsearch or controllers, this the only update that applys to me (maybe)
Posted Thu 04 Oct 12 @ 12:01 pm
Support staff wrote :
It's how often the LED's are updated (Refreshed.) For controllers with jogwheel LED's that indicate the disc position, this will result in smoother movement.
godj30349 wrote :
And can somebody explain to me what "increased refresh frequency for HID/MIDI controllers" means.
Posted Thu 04 Oct 12 @ 1:37 pm
There are many bugfixes in the code already but not woth to give detailed information about every changed byte of the code.
There was a problem with some UTF characters and the correct translation and this get's fixed.
Greets, Heiko
Posted Thu 04 Oct 12 @ 2:00 pm
Just a quick question, does anyone know if 8 is going to support the Denon sc2900's?
Im moving back from Serato as soon as they are supported...
Posted Thu 04 Oct 12 @ 2:11 pm
Good chance of that ;)
Posted Thu 04 Oct 12 @ 2:22 pm
Hi,
There were 2 bugs in 7.0.5b:
1. Playback only at 44.1KHz in Advanced Config.
2. The assign_controller MIDI keymap command is broken. I was told it would be fixed in the next version (http://www.virtualdj.com/forums/164813/PC_Version_Technical_Support/Custom_MIDI_Keymap_Question.html).
Have these been fixed in this version? They are not listed in the changelog.
Cheers.
Cheers.
Posted Thu 04 Oct 12 @ 3:38 pm
Keith
Keith
i got the Numark N4 with the 7.05 virtual dj LE edition.
Posted Thu 04 Oct 12 @ 3:57 pm
The thread in your link states that assign_controller would be "looked at and fixed in version 8".
Posted Thu 04 Oct 12 @ 4:11 pm
Not quite. *I* asked when version 8 was going to be released, because at the time we all thought version 8 was going to be the next version.
djdad actually says:
djdad wrote :
instead of
deck 1 assign_controller "CDJ400" 1 (which is currently not working (the bug will be fixed in next version))
(Emphasis mine)
Posted Thu 04 Oct 12 @ 4:17 pm
Cant test right now.. but did you try :
deck 1 assign_controller 'CDJ400' (single ' )
Also ... if you have 2, it might be logic of 'CDJ400-1' and 'CDJ400-2'
But if its broken, i'll put it on bug list notification for dev team.
Posted Thu 04 Oct 12 @ 4:59 pm
My laptop's in for repair at the moment. I'll try it in the next week or so and let you know.
Cheers!
Posted Thu 04 Oct 12 @ 5:13 pm
