I just recently started using it instead of my pcdj dac3. And upon hooking it up the left side pitch slide no longer controls the software. I tried working the slide to force a catch and unplugging it repeatedly. Nothing works. Everything else is fine. I use the latest version of vdj with virtual vinyl box
Posted Sat 11 Aug 12 @ 3:22 pm
Hello. I assume you mean Numark DMC2 ?
In that case please check the soldering inside. Me and many of my collegues had similar trouble, like pitch going wild, button stop working etc.
I really liked the layout so I did re-solder the PCB-board totally. After that it worked for many years without problem.
Now however, it has been replaced.
I guess you have a broken soldering for your left pitch fader.
Posted Sun 12 Aug 12 @ 5:12 pm
Please don't post the same message more than once. You have already also asked the same question in the following topic, where you can also find an answer:
https://virtualdj.com/forums/105555/VirtualDJ_Plugins/finally__i_edited__the_dmc_2_this_is_how.html
NOTE: This is a hardware issue and should have been posted in the hardware technical support forum: https://virtualdj.com/forums/31/Hardware_Technical_Support.html
Posted Mon 13 Aug 12 @ 6:18 am
