Topic: Need some help..
Hi there!
I need some help to get good samplers and really good effects that doesn't ruin the music. I want to learn more like the following clip on Steve Angello's mix http://www.youtube.com/watch?v=jIvUsiZ57MU Something like that whom can change the voice and all of that!
I got a DDJ-Ergo and Virtual DJ of course + that I'm working on Mac
Would really appriciate answers!
-Thank you
Posted Mon 07 May 12 @ 6:37 pm
It is only possible to add effects while using the Pro Full.
The good news is, we offer you a discount.
Just insert your VDJ LE serial at >> Upgrade to VirtualDJ Pro Full << and press continue.
https://virtualdj.com/buy/
I've bought the VirtualDJ PRO FULL now and I can't still do it.. Need an effect who drains out the vocals and a effect that can control the voice.. Give me a tip! You should know what I mean! If not, check the video again.
And why is there no "Key" on the Pioneer DDJ-ERGO V controller? while it is on the skin at the VDJ PRO FULL
If you are looking to remove the vocals or instruments from the song, please see: https://virtualdj.com/wiki/How%20do%20I%20remove%20the%20vocals%20or%20instruments%20from%20a%20song.html
The DDJ-ERGO V doesn't physically have a key knob (Manufacturers design their controllers to suit their own specific requirements, not the default skin of VirtualDJ.) However, you can easily map this to another knob that you don't need if you wish - Please see: https://virtualdj.com/wiki/How%20do%20I%20map%20my%20MIDI%20controller.html
You should be able to download any effect you want. See https://virtualdj.com/addons/effects.html
Make sure to DL only Mac-effects (recognizable by the Mac-logo on the DL-link)
What you hear in the clip is done with a vocal-only part of the song. (the Pioneers used in the clip can't extract vocals out of the song)
Any Mac Vocal Remover coming soon????
