How about if I buy a controller licence and wish to upgrade, is the initial layout cut from the upgrade price?
Posted Mon 12 May 14 @ 2:13 pm
No. If you buy a controller license then that is what you have. If you but a new controller you will need to buy a me controller license
There is no upgrade route to Infinity.
Posted Mon 12 May 14 @ 2:15 pm
So a DJ gets his controller licence for upto $150 and if he gets good enough for a paid gig he has to spend $300 more? That doesn't sound like it promotes purchasing the pro upgrade.
Next question about the djdecks users offer, They get a free upgrade to VDJ 8, pro infinity, I'm assuming?
I've checked the offer and it appears so, is the offer still valid?, If I buy djdecks today will I be a pro infinity licence holder come release day?
Posted Mon 12 May 14 @ 2:26 pm
You can't buy djdecks for a way too long time now....
Posted Mon 12 May 14 @ 2:39 pm
Actually controller licenses can be $199 for the Pioneer DDJ-SZ for example.
It also worth remembering that you also get updates. The current LE format gets minor updates but not major ones.
But ultimately you are correct. Someone could spend $199 and then need to spend a further $299 on Infinity. But the chances are there would be a large time scale between this otherwise the sensible choice is to buy Infinity in the 1st place.
And as Phantom has said - you can no longer purchase djdecks.
Posted Mon 12 May 14 @ 6:44 pm
According to my Account Settings, I have VDJ8 Pro Infinity but the software on my Mac is telling me I need to buy it. When I go to enter the serial number it will not allow me to upgrade on your website.
Posted Sat 28 Jun 14 @ 12:45 pm
No need to upgrade - just enter your username and password to login and activate your license on your Computer.
You dont have to pay for it.
Greets, Heiko
Greets, Heiko
Posted Sat 28 Jun 14 @ 12:53 pm
if ther is a update
what is the downloadlink to it
Posted Sat 16 Aug 14 @ 12:24 pm
click above that says DOWNLOAD
or here is the link for you
https://virtualdj.com/download/
Posted Sat 16 Aug 14 @ 12:53 pm
