I suggest you to write the label "AUDIO CROSSFADER" / "VIDEO CROSSFADER" over a "button" instead only over the panel, so it's more intuitively to press it for change this mode. :-)
Anyway: GREAT JOB !!! I'm waiting the lower resolution version (1366x768).
Thank You for this work !
Posted Thu 17 Jan 13 @ 2:54 am
I have an issue with the 1366x768 resolution. When using some plugins, Firetext for example, not all of the controls are viewable.
Posted Tue 29 Jan 13 @ 7:35 pm
Unfortunately, in the 4Decks mode, the height of the Browser (especially in 1366x768) is very limited. You can switch to the 2 Decks mode and view more sliders.
That is a common issue with effects having lot of settings/sliders and small browser.
Nothing we can do about it.
Posted Tue 29 Jan 13 @ 11:01 pm
Thanks for the response. I've been using it in 2 Deck mode, just miss the 4 decks... I wasn't aware it would become and issue until I got this new laptop, lol.
Posted Wed 30 Jan 13 @ 6:49 pm
At a minimum your display and/or laptop screen should support:
1440x900 [16:10]
1600x900 [16:9]
Resolutions like 1366x768 is just not enough resolution...
1440x900 [16:10]
1600x900 [16:9]
Posted Thu 31 Jan 13 @ 7:08 pm
Nope, max res is 1366x768, and for most things, it's fine. I am using the mixtrack skin, it leaves a lot of room for everything. Even the 2 deck cut a little off.
Posted Thu 31 Jan 13 @ 7:20 pm
Any news about the date to release v3 lower resolution (1366x768) ?
Posted Thu 07 Mar 13 @ 8:18 am
DjDad Hello, I love this skin and use it (ver 2.1) with great satisfaction.
Is there any news about the release of ver 3.0 of this skin, for lower resolution (1366x768) ?
Thank You for attention.
Posted Mon 22 Apr 13 @ 1:51 am
Update
Version 3.1
- Added Slip Mode Button (requires 7.4)
- Added Loop Roll Button (requires 7.4)
- Added 1280x800 1366x768 1440x900 resolutions
1280x800, 1366x768, 1440x900
Download Link : https://virtualdj.com/addons/14226/VirtualDJ_7_(4_Decks_Swap).html
HD (1600x900, 1920x1080, 1920x1200)
Download Link : https://virtualdj.com/addons/13812/VirtualDJ_7_(4_Decks_Swap_HD).html
Version 3.1
Posted Fri 26 Apr 13 @ 8:58 pm
Thanks ;o)
Posted Sat 27 Apr 13 @ 1:41 pm
i still have the same problem with the sampler volume disappearing while using 4 decks with the 1366x768 mode but so far the best skin i came across!
Posted Sun 28 Apr 13 @ 7:31 pm
Unfortunately, the height of the browser in the 4decks 1366x768 version is very limited and several things may not be visible, such as the Sampler Volume faders.
You will need to switch to the 2Decks View in case u need to get that information. Its only a click on the skin :). I could also come up with a script (assign to a keyboard or controller key) that could toggle to 2 Decks view (Sampler Page) and back to 4 Decks view (Browser page), if that would be convenient for you.
I am considering on creating a custom Sampler Page Panel though. Noted for version 4, whenever that comes.
Posted Sun 28 Apr 13 @ 7:49 pm
No wave on player 4 in the top window when I change the wave and my Mixer?
Posted Tue 30 Apr 13 @ 8:23 pm
You re posting in the wrong thread. The above is a skin i made after a request ... https://virtualdj.com/forums/174736/VirtualDJ_Skins/Challenge___Can_someone_make_me_custom_4_deck_3-1-2-4_skin__.html
But to answer to your question. This is probably a software bug, if the rhtyhm is zoomed out too much.
Posted Wed 01 May 13 @ 10:38 am
THANK YOU DjDad !!! Great job !
Posted Thu 02 May 13 @ 3:11 am
What a great skin! Looking forward to using it live... :)
A small typo in the XML:
- In the pop-up sampler window at the bottom of the screen, sample 12 shows the linear progression of sample 2 instead of 12. The code is in the "--slot 12--" section:
"<visual panel="sam4" type="linear" source="sampler 2 position" orientation="horizontal">"
...and the 2 should be a 12.
I almost feel bad reporting this as the whole project is superb! Great job!
Regards,
Duggy.
Regards,
Duggy.
Posted Sat 20 Jul 13 @ 8:49 am
Just wanted to post to say thanks for this skin. Have been using the swap skin a while now and missed it being updated for some reason, the update is fantastic. Thank you.
Posted Sat 04 Jan 14 @ 7:31 am
