Forum: VirtualDJ Skins
Topic: [NEW] Default 4 Deck SWAP - Page: 1
Posted Sun 23 Oct 11 @ 11:57 pm
Mixer Panel
Video Panel
Scratch Panel
You will notice that the colors of the non-leftdeck/rightdeck decks are faded
Also none of the resolutions is resized with the Tool. They all are original creations, therefore you will enjoy crystal clear graphics.
Enjoy !!!
Nice that you have native resolutions.
Can this swap technology be used to send a track back to waitlist from a deck?
Daddy LIKE!!
I've been waiting since 2006 (since I started using a 17" 1920x1200 screen) for this. I love the layout and crisp clear no BS layout! Deck Swap?!?! How cool is that?!?! ;)
Sir, if you're not on the Atomix payroll, you should be! Do you have a favorite charity that I can send a donation? ;)
Thank you for all your hard work. I truly appreciate this skin and I hope others do too! You are an answer to VDJers wishes and hopes!
Okay I am done kissing your arse! But really... Thank you!
Luke
Hey Djdad, can you Skin in 1366-768
Super Ace,
Can you send it to me, for some reason I can't resize anymore and I need the same res.
I'll PM you my email.
Very good work!
+1, please resize and add it in the pack.
is is possible to modify this great skin to switch between 2 Decks / 4 Decks
Is it me or are those platters (decks) too small?...look more like Rotary Buttons ....hmmm
Optical illusion. I'm sure the originator of those platters made sure they were the exact same size.
there is a joke in there somewhere...right Terry?... ;-)
Check the conditional panels i created to show the level sliders according to which deck is leftdeck or rightdeck
You must add another condition for each one of those panels
Example
<panel panel="mixer4d" id="lvl1on" group="lvls1" visible="skin_panel '4decks' on ? skin_panel 'mixer4d' on ? deck 1 leftdeck ? true : false">
<size width="30" height="79"/>
<pos x="800" y="370"/>
<down x="+0" y="+0"/>
</panel>
You will need to do this for the scratch panels too, and any other conditional panels, you may create.
PS. I will create a 2/4 deck version soon.
UPDATE
Ver 2.0 will be ready very soon.
1600x900 version is already done.
1. Added 2 deck mode, and the colors still change/swap according to which deck is leftdeck or rightdeck.
2. Added Browser Fontsize Enlarge/Reduce buttons
3. Added Unload buttons
Anything else you need to see in the next update ?
PS. Resolution 1366x768 will be also added :)
Thanks for your comments.
Yes to Skin 1366x768 thank to DjDad.
i tryed to build a 1680x1050 skin and had a plan to use the free 40 px at each player between mixer & player for
a. scratch waveform
and b. for all switch button like smartloop, smartcue, smartplay.... at one playce
is this a idea for you too?
I need to keep the default layout, so these will stay as they are now.
One thing i was thinking of adding is the jog mode (browse, search, loopin, loopout..etc). Many controllers have the jog mapped as jog mode, and its good for the user to know on which mode is the jog.
Great work djdad. My new default skin :)
Congrats Bob.. Nice update...
Update Beta version
Ver 2.0 is ready but i have a small loading issue. When Virtualdj starts, skin takes quite a few seconds to load, but loads fast when switching between skins. Can you please verify this ?
This is the reason i did not actually update the ver 1 skin (still available), and i uploaded a Beta version (1600x900)
Download Link
https://virtualdj.com/addons/13812/VirtualDJ_7_(4_Decks_Swap).html
- Added 2 Decks mode
- Added Browser Font size (+-) buttons
- Added Unload button
- Added Sampler Beatlock and Sampler Loop
- Added Battery Status Indicator (Requires SBDJ Battery Status Plugin) PC only
- Added Jogwheel mode indicator
Feedback is appreciated
21%
