I have a Mixtrack Pro using Virtual DJ 7 pro and a M Audio Axiom 25. I would like to map the Axiom to some of the features on VDJ that don't have controls on the MTP.
For example the filers and key change for each deck mapped to 4 of the rotary dials. And I could use 2 of the pads to launch the FX and 2 more of the rotary's for the FX volume. Further I would use some of the keys to change the size of my loops.
These are all things now that I have to use my mouse for and would really like the better control. PLEASE HELP as this would be a pretty cool set up to play with!!!!
Posted Mon 15 Aug 11 @ 1:16 pm
Is this even possible?????? I really wish it was!!!!!!!!!!!!!!!
Posted Tue 16 Aug 11 @ 8:55 am
Some one has got to have some sort of programming advise here PLEASE!!!!!!
Posted Fri 02 Sep 11 @ 1:35 pm
I think they are not replying from non-LE or PRO user members. :) I think if you have upgraded your VDJ to pro you may be able to use your MIDI device to trigger actions that you desire to use. I am not familiar with mapping though. I have an mpk mini and I really want to use it too the problem is I'm still using the LE version of VDJ
Posted Mon 12 Mar 12 @ 12:42 pm
Please register your Pro serial number on the page https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: https://virtualdj.com/buy/
Once you have done this, please see our FAQ pages:
https://virtualdj.com/wiki/How%20do%20I%20map%20my%20MIDI%20controller.html
https://virtualdj.com/wiki/How%20do%20I%20change%20the%20mapping%20for%20a%20button.html
Posted Tue 13 Mar 12 @ 7:17 am
