Topic: Quick video of me messing about... - Page: 3
Simon..quick question
The way it is working now both decks both Jogs manipulates the filter.No problem there.but is there a way to kill this effect so I can jog
like it did before the remapping? example....turn off all effects so I can adjust the blocks to line up in sync for mixing?
When I throw the rev toggle the cut effect activates and turns off when needed..but the filter effect stays no matter what...I cant use the jog wheel for aligning up a mix.
How do you handle a situation like this? cant seema way to save this mapping as different name ..is there?
Man, you opened up a huge can of worms with this one. All I can say is that is just SICK!
I'm almost willing to pay money just to see you make us a quick instructional youtube vid so we could see exactly how you are mapping VDJ to make this incredible effect.
I think the whole community could prosper from your advice in further screenshot depth. Keep up the great ideas.
James...the mapping is designed so that when you want to disengage the "Scratch Effect", you move the REV toggle from it's "ON" position all the way to the to BLEEP and release.
If you want, have a look at your controller and and let me know if you want me to map the effect ON/OFF to another button. I have mapped the effect onto my Hercules DJ STEEL and I use the DJC BUTTON 1 to switch the effect on and off.
Aaro2n...steady on the paying thing...lol sit down and and I'll see what I can do...
Simon it works.....I didnt see that..my brain fart...
Thankyou....it works awesome!
hi simon,
Is this effect possible with my 4mx? Can you help me with the mapping pleaseee!
Sorry, VirtualDJ LE does not support custom effects or mapping, except during the 20 day trial of Pro.
To be able to use custom skins, effects, mappings and much, much more you will need to upgrade to the full VirtualDJ Professional. Your VirtualDJ LE entitles you to a discount off the cost of upgrading. To receive this, please go to https://virtualdj.com/buy/
lol..stand but if it works then hey! =)
that's helpful!
Thank you very much!
