oh yeah just learned this, when you take the bettery out, DO NOT FORGET to reboot your pc!
Posted Mon 05 Dec 11 @ 3:42 am
I use a hercules DJ controller plugged into a sony vaio... for some strange reason during the songs i am mixing it always jumps and buffers, it is very annoying and does it on every song i play. I have played through my speakers on itunes and it doesnt buffer - please - i desperately need help.
Posted Sat 03 Mar 12 @ 9:26 am
This means that you have performance issues with your computer and/or it is not optimised for VirtualDJ:
Please see our FAQ pages:
http://www.virtualdj.com/wiki/Performance%20Issues.html
Posted Sat 03 Mar 12 @ 12:50 pm
hey im a VDJ DJ 7 USER WHIT THE RMX CONTROLLER I played yesterday on a party and it was the first time that i play on sound installation and stuff. but i got some technical problems its al the time by switching whit songs ore mixing it and i get to malfunction en disorders so pls help me out. i was completly to disappoint of the program. i think its the VDJ SOFTWARE ORE THE RMX. PLS HELP !
Posted Sat 03 Mar 12 @ 2:52 pm
The RMX comes with VirtualDJ v5 Console Edition, not v7.
Please register your Pro serial number on the page http://www.virtualdj.com/users/edit.html and download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased the software, then please support it and its future development by purchasing it: http://www.virtualdj.com/buy/index.html - Your RMX entitles you to a significant discount of 50% off the cost of upgrading.
Make sure that you also have the latest drivers and firmware installed: http://www.virtualdj.com/wiki/Common%20Device%20Drivers.html
Also, check that your computer has no performance issues and is optimised for VirtualDJ: http://www.virtualdj.com/wiki/Performance%20Issues.html
Posted Sun 04 Mar 12 @ 4:12 pm
Dj pusher - u r a genius! I had the same problem with the "not responding" message. Tried all the fixes sent by Hercules and virtual dj. Optimized system, uninstalled and reloaded the program and nothing worked. Finally, I tried taking the battery out of the laptop and it worked great! Thanks.
Posted Fri 01 Jun 12 @ 4:56 pm
I agree. The battery issue caused my Virtual DJ LE 6 to freeze, right before I was supposed to start my set! Taking out the battery and rebooting solved it. My laptop was a Lenovo x61
Posted Thu 07 Jun 12 @ 10:47 am
I think the battery thing has solved my issues!!! I have a few gigs coming up in the next few weeks, I'll let you know. This has happened on and off for two years. It plays well for two gigs..and it happens again. I have bought new cables, RMX and thought about a new laptop...but I thought everything else is running on my cpu just fine, so it must be the rmx or my computer...right? When I read this post it was 95 degrees outside and when I took my battery out it was hot as hell. I was just practicing for tomorrows gig. It must have happened 5 or 6 times and since I took out the battery...nada!
If this is truly the cure, I sincerely owe you a sincere debt of gratitude.
P.S. I am using a purchased copy of VDJ 7 and windows 7. 8gb ram
Thank you for posting!!
DJ Joe Expo
DJ Joe Expo
Posted Fri 06 Jul 12 @ 7:03 pm
you do not have to take out your battery just buy a power USB hub and should be good
Posted Sun 07 Sep 14 @ 10:02 am
This thread is being locked for being old.
Posted Tue 09 Sep 14 @ 2:55 pm
