Forum: Old versions
Topic: American Audio VMS4 Discussions - Page: 16
There are no changes in that definition/mapper package - it is the default mappings.
Is there something wrong with me that now I'm thinking of returning the VMS4 and picking this up...?
http://www.musictrends.com/remix-case-combo-p-13288.html
Will I able to somehow control more than 2 decks with that when VDJ7 is released?
Just need an upgrade from Numark TotalControl that can be used with multiple decks on VDJ7.
Here is a sample of the hum I hear when I put the channels to analog. I dont get any hum in USB, its nice and quite but as soon as I turn them to analog I get the hum, the more channels I more to analog the louder it gets. Does anybody else get this hum in analog?
http://www.4shared.com/audio/NFlfesIB/ALE-0003.html
I had an RMX and that thing never gave me a problem. I think its perfect for VDJ
I only got rid of it because I switch to windows 7 64bit and at the time I switched Hercules didn't have drivers for windows 7 64 bit.
Can cstoll let us know if we can toggle between decks on a controller like the RMX or TotalControl? Or at least be able to control a third or fourth deck?
If you are asking about the next version release - Yes, I will be updating the mapper to support the additional decks that will be possible with version 7.
@Koz, I imgine you could. Think about it, you only need 1 timecode to run 2 decks..................and as far as that remix thing goes its only a 2channel soundcard so wouldnt you need to run your other 2 channels else where? I've never used a controller, YET, but I dont see how 2 channels could ever be better then 4. With 2 no PFL for samples or loops. With 3 or more you could rock an instrumental, a accapelle and still be able to scratch or them both AND blend in a 4th track!!
Just my 2 cents, lol
Huey
Cstoll, thanks for the answer.
Beatbreaker, you are right. Only way for it to work, using the TotalControl, RMX or any other 2 channel midi controller, would be to connect my DJ io as well.
I just need to see how my 1st gig goes this weekend with the VMS4 and pray that I don't have any problems.
Also, praying that the bugs are fixed and waiting very very anxiously for VDJ7.
Not the Total Control. Would probably need 2 DJ io's.
Just like any other gig, make sure ou set it all up at home first and bring a backup to the gig. Im sure it'll go great! Have faith in the DJ gods, lol!!
Huey
Thanks beatbreaker.
Ok. I want to be absolutely ready for this weekend with the VMS4.
What are the current correct settings? On hardware and software?
It seems there are 2 options for sound card the way I have it... VMS4 and ASIO.
Very nervous even though I have played around with it and only issue I see right now is the mic distortion.
I have newest driver and original firmware.
Funny thing is that I see everybody complaining about the mic distortion and I don't have any problems with the mic.
Try it in a large club with a powerful system. It's dreadful!
What mic ae you using?
Well there's your problem!
The VMS4 is aimed at mobile DJs.
Look at the price point for starters. Do you really expect to get a club quality four channel mixer and two USB deck controllers for £400? The product you should be looking at is the Xone:DX, which is more than twice the price!
I think that for its intended market, the VMS4 serves its purpose well.
OK, it has its limitations and quirks - but a lot of that is down to it running from only 5v.
You can't expect sports car performance from a runabout. :-)
I agree but the mic quality is unworkable in my opinion, not just budget quality.
So can anyone help me on the settings?
46%
