It is an optimized Windows XP installation dvd. Not made by me.
I have download it for free from an other audio forum.
In this windows setup/installation there is all unnecessary removed and it is optimized for DAW like VDJ.
If you have an key i could upload it for you.
cu
pOpY
cu
pOpY
Posted Mon 22 Mar 10 @ 4:11 pm
I have sent you a pm.
Posted Wed 24 Mar 10 @ 8:19 pm
Hello,
the version is fine.. :)
But the status window is a for errors, and not for messages like "no internet connection"...
I have all disabled and know that... please please remove that, i will see the really important messages!
Greetz
Ava
Greetz
Ava
Posted Thu 25 Mar 10 @ 3:36 am
Hello VDJ developement team. Any news on when we can get the American Audio DP2 mic working?
Posted Thu 25 Mar 10 @ 10:36 pm
@pop hey tried your setting but dint work so i am will hang with serato itch until it works again
Posted Sat 27 Mar 10 @ 10:43 pm
I had previus versions of vdj installed and I had NO problem playin all my AVI videos ALL were playin correct now with V6 7 dont I think that I shuld change All my avi files because this new version . Does any one have the same problem , does anyone have avi files and vdj 6 7???
Posted Sun 28 Mar 10 @ 7:20 pm
What codec was used to encode your AVI files ? You can use something like GSpot ( http://www.headbands.com/gspot/ ) to identify what the codec is on the file.
Posted Sun 28 Mar 10 @ 11:36 pm
Had a gig on saturday with 6.0.7 + NS7.
All went fine with no major problems, except that on deck A no waveform where displayd after 3hours of playing.
The Max. Load Setting was on 15min. I have tried "always" but nothing helps.
cu
pOpY
cu
pOpY
Posted Mon 29 Mar 10 @ 1:16 am
Saturday 27-03-2010 I play a set from 8pm to 2 pm with virtual dj 6.07 with Dn-HS500 In CD mode because vinyl mode don't work.
The rest of the program works fine no problems except the vinyl mode.
regards Dimi
regards Dimi
Posted Mon 29 Mar 10 @ 12:04 pm
Gspot shows : Codec XVID Name XviD ISO MPEG-4 I been ripping with Clone dvd movile since 2 -3 years I was doing VOB first them I went to AVI and ON PREVIOUS VDJ versions 5 ,6 01 , 6.05 Virtual was playin then just fine!!!. But NOT now on this vdj 6.07
BUt if Virtual is gonna be like this from now.... How should I ripp starting from now. or what do u recomend sorry for all my collection!!
Posted Mon 29 Mar 10 @ 2:31 pm
Codec DIVX Name DivX 4 (OpenDivX) 720x480 wxh
SORRRRY THIS ARE MY AVI FILES RIPPED LIKE!!!!! I put the wrong one above thissssss is
Posted Mon 29 Mar 10 @ 2:39 pm
Having the same pitch issues but with my denon dn-s3700s. It sucks because this version seems to be a lot better.
Posted Mon 29 Mar 10 @ 9:59 pm
I appreciate you guys on the VDJ team looking into the numark ns7 issues... but numark and serato have yet to crack an official driver for windows 7 64-bit operating system.... Now VDJ 6.0.5 is the best version that has been working for me and the ns7, but I do not think VDJ is completely to blame.... all I know is I spent 1200 dollars on a system that has been out for a while and windows 7 has been out for sometime but yet they can not crack the driver for 64-bit windows 7?
Sorry guys for venting I am just getting really frustrated bc I am pretty much doing every gig unstable because of this issue with the driver....
But to the VDJ team thanks for all your hard effort and working so hard to get this problem resolved with the ns7....
I am pretty sure me and alot of dj's out there who use the ns7 are really appreciative!!!!
Posted Mon 29 Mar 10 @ 10:19 pm
Now here it is:
https://virtualdj.com/forums/126508/General_Discussion/Windows_XP_-_SP3_Audio_Optimized.html
Have fun
cu
pOpY
Have fun
cu
pOpY
Posted Tue 30 Mar 10 @ 1:28 pm
jamesvanek wrote :
Any one else notice that sometimes v. 6.0.7 will not play a video? Seems like two or three times a shift I have this happening. The audio will play but only a black screen where the video should be. Plugins still work fine but no vid. ???
DJ James
DJ James
Alan Todd wrote :
Yes. I've noticed the same problem. I have to reload the track to get the video to play. Happens on vobs. mpg and avi
Same here did this on a couple of videos just a black screen no video. Also notice the problem where a video wouldn't fully load is back in full force. This problem used to show up only after playing for 6+ hours. Last weekend it was happening like every couple of hours.
Posted Tue 30 Mar 10 @ 5:47 pm
Perspolis wrote :
Ok so im on MAC i play with my NS7 everything is fine cept it wont scratch it only stops rewinds or forwards wit the vinyl and its super laggy, its not even on point at all I tried serato itch, and the vinyl scratching works perfect.
I have the same problem.. though it was my Mac.. but then i tried it on a new Mac and still the same problem.. so I Virtual dj.. came with a better. version but worst for Mac users.. the 6.07... Sucks.. Hopefully 6.08 will work correctly.. and be very stable...
Posted Tue 30 Mar 10 @ 10:13 pm
THANKS
this version v6.0.7 is much better so far
files load quicker, and more stable than other v 6.0.x, main video output is a little juddery, very slight tho,
text2d still has problem with search bar of tracks when you use it, hope it can be fixed soon as its very good plugin when working.
still testing with my set up,
Keep up the good work team.
Posted Wed 31 Mar 10 @ 9:02 pm
i retried it with my mixvibes records and it works great
key ajust works better :) on just support dx 11 and where good
Posted Fri 02 Apr 10 @ 8:51 pm
Guys, Right now there is a Known Issue With the motorized platters in VDJ6.0.7, It's affecting Dennon motorized platters and Numark Ns7 but support has assured me that they are vigoursly working on a fix.
Ive been Instructed and support has made 6.0.5 available in my downloads to go back to 6.0.5 until a new update is provided. Please contact support and ask for 6.0.5 in you doanload center.
By the way Im praying for a fix because with 6.0.5... I have the video freeze issue. so with either version I cannot use vdj, So believe me I know your frustration
Damn that 3.5 year old Win XP laptop for giving it up on me !
Sincerely DJ JAMM
Sincerely DJ JAMM
Posted Mon 05 Apr 10 @ 12:14 pm
Having issues with denon hs 5500..still havent gotten a workaround...only one deck is active..if i switch layers the active deck stops.....sucks back to 6.02....funny, i was suprised to walk into a club in nyc to find a dj using virtual dj 5.07...and he says he aint loading any bug updates n i doubted him till i updated.
Posted Wed 07 Apr 10 @ 12:08 pm
