Hello,
We just released a new version of VirtualDJ, v6.0.7.
As usual, this version is free for all registered users of VirtualDJ Pro and VirtualDJ Basic.
You can download it from your download center.
This version has an improved video engine, adds many new natively supported controllers, and fixes a few harmless bugs.
https://virtualdj.com/wiki/VirtualDJv6.0.7.html
Posted Sun 07 Mar 10 @ 6:23 am
O JEEEA THANK YOU
Posted Sun 07 Mar 10 @ 7:50 am
Woohoo. Cant wait to check it out.
Posted Sun 07 Mar 10 @ 8:26 am
Good job.
Posted Sun 07 Mar 10 @ 8:42 am
Sorry if this is a dumb question...
Should I un-install the current version (6.0.5) and then install the latest version (6.0.7)
or
Is it best to just upgrade by downloading and running the installer for 6.0.7.
This is my first time upgrading Virtual DJ and I want to make sure I do it correctly.
Thank you,
Robert Pfeifer
Pifemaster Productions
www.pifemaster.com
or
Thank you,
Robert Pfeifer
www.pifemaster.com
Posted Sun 07 Mar 10 @ 9:20 am
You can directly install 6.0.7
Posted Sun 07 Mar 10 @ 9:23 am
Thanks for the quick response!
Robert Pfeifer
www.pifemaster.com
Robert Pfeifer
www.pifemaster.com
Posted Sun 07 Mar 10 @ 9:27 am
I have been waiting for this new version of VDJ, can't wait to try it out.I must say nuff respect and honor to the VDJ Team, they are always working,always improving the software,always supporting all the users.This DJ software is in a class by itself, serato is playing catching up right now but for all you DJs, VDJ is ahead of the game,the only software that can probably use with any equipment.VDJ is the Boss.
Posted Sun 07 Mar 10 @ 10:42 am
Thanks! Can't wait to check it out!
Posted Sun 07 Mar 10 @ 12:03 pm
VDJ comes through once again.
Thank you.
Thank you.
Posted Sun 07 Mar 10 @ 1:00 pm
Thanks VDJ for constantly improving the software!!!
Posted Sun 07 Mar 10 @ 3:02 pm
A new mapper for Dj Tech Kontrol one is included !
Posted Sun 07 Mar 10 @ 3:06 pm
Crazy problem with this release. Crazy pitch problem when doing anything with the computer. change directory speed up and slow down. load a deck speed up and slow down. This only happenes with my NS7 and laptop setup does not seem to effect my RMX setup. Reloaded 6.0.5 problem went aeway.
Posted Sun 07 Mar 10 @ 3:18 pm
Nice one VDJ, thanks!
Posted Sun 07 Mar 10 @ 3:22 pm
Is there support for the Numark MIXDECK and the V7 in this release?
Posted Sun 07 Mar 10 @ 3:43 pm
Update just in time. But no help with my video freeze problem in XP. Any hardware acceleration above 3rd noch from left on slidebar still locks up video.
I also loaded the new Registry Tweeker and set my UseFullMemory to 100. No idea what number to put in here. A help guide would be excellent please. (Found the help guide in https://virtualdj.com/wiki/RegistryValues.html)
Back to VISTA for me. Thanks for the VISTA guide to turn off the unnecessary stuff. To VISTA ...Yes I want to run the task... why are you asking me if I really want to do it? Didn't I just push some buttons to do what I want you to do !!! Don's ask me... just DO IT ! Geeze !
HP DV-9500 with NVIDIA 512M 8600M GS and a little bummed that update won't allow me to keep XP... the lean and mean.
Regards,
Jim
Regards,
Jim
Posted Sun 07 Mar 10 @ 3:54 pm
Yes, on the mappers tab uncheck the 'Show only connected' to see the whole list ...
Posted Sun 07 Mar 10 @ 3:58 pm
Thanks VDJ Team for the update.
Posted Sun 07 Mar 10 @ 4:53 pm
Quote :
good!!! ;) thanks VDJ Team & Atomix Productions for this new update, and supporting too, to the VDJ Basic Users!!!
regards
DJ POTTER PRODUCTIONS
Posted Sun 07 Mar 10 @ 4:56 pm
Ok so im on MAC i play with my NS7 everything is fine cept it wont scratch it only stops rewinds or forwards wit the vinyl and its super laggy, its not even on point at all I tried serato itch, and the vinyl scratching works perfect.
Posted Sun 07 Mar 10 @ 6:34 pm
