I sad to report that my machine still shows the memory leak and still has the same freeze, with the exception that the freeze undos itself, plays a few seconds and than stutters and freezes again.
so, a zero on the memory leak,
1/2 point on the freeze thing.
Its all mute, cause I just dumped $850 on hardware and built a desktop for my shows that has absolutely no video freeze running Win 7 64bit on a quad core processor, 4gigs of ram and a DDR 5 Nvidea graphics card. This desktop has performed with VDJ like a dream and is actually fun again. I highly recommend going desktop!
I did notice that the files seem to load a lot faster, so that's the one thing with 6.05 on my new home brew system is that there was still slow loading files on one deck, so I'm looking forward to this version solving that.
Thanks again Teamers for all of the hard work.
Posted Sun 07 Mar 10 @ 7:53 pm
sclavel wrote :
Hello,
We just released a new version of VirtualDJ, v6.0.7.
As usual, this version is free for all registered users of VirtualDJ Pro and VirtualDJ Basic.
You can download it from your download center.
This version has an improved video engine, adds many new natively supported controllers, and fixes a few harmless bugs.
https://virtualdj.com/wiki/VirtualDJv6.0.7.html
My big problem with 6.0.5 was that it would just stop about 2 -3 hours into a gig. I reverted back to 6.0.1 and the problem so far has not accured. Do the memory leaks you refer to in https://virtualdj.com/wiki/VirtualDJv6.0.7.html address this problem? I am afraid to update until I am at least aware of that issue being addressed. The problem I am having with 6.0.1 is that automix seems to burp or pause briefly from video to audio, which makes it unusable.
Posted Sun 07 Mar 10 @ 8:54 pm
Anybody notice the new tick box in Config/Video for Decode in Multithread? :-)
Posted Sun 07 Mar 10 @ 9:05 pm
hi!, in VDJ i got only the NS7 mapp, i need the midi mapp for the decks of the mix deck!HELP!
Posted Sun 07 Mar 10 @ 9:30 pm
You will either need to wait for trial of v6.0.7 to be released or purchase VirtualDJ Pro https://virtualdj.com/buy/
Posted Sun 07 Mar 10 @ 9:47 pm
OH! Thanku Thanku Thanku
Posted Sun 07 Mar 10 @ 11:14 pm
Wow, Thanks for the update. Good thing I cross graded last week. Perfect timing & away we go!
Posted Mon 08 Mar 10 @ 2:51 am
Great !! but now I wonder if the clipbank plugin will still work since i just went from 6.5 back to 6.4...maybe someone can try it first?
Posted Mon 08 Mar 10 @ 4:42 am
drzinc wrote :
Crazy problem with this release. Crazy pitch problem when doing anything with the computer. change directory speed up and slow down. load a deck speed up and slow down. This only happenes with my NS7 and laptop setup does not seem to effect my RMX setup. Reloaded 6.0.5 problem went aeway.
I also had this problem before 6.0.5. I have talked to a german mod in the german forum (da solltest du vielleicht auch schauen ;-).
Please try to remove all customs mapper files from NS7 (move it out of the mappers directory to an other) and use the default mapper of the new vdj 6.0.7.
Please give me feedback
I could try VDJ 6.0.7 with my NS7 this week.
cu
pOpY
Posted Mon 08 Mar 10 @ 6:05 am
its been fixed. You have to reload the slots again though.
Posted Mon 08 Mar 10 @ 10:09 am
Has any other of you tested vdj 6.0.7 with the NS7?
Does the MIC works?
cu
pOpY
Does the MIC works?
cu
pOpY
Posted Mon 08 Mar 10 @ 10:43 am
But my issue of leftover sound snippet is still there. <sigh>
I'll hafta see on my end how it behaves w/ video & kroke tracks.
Posted Mon 08 Mar 10 @ 10:44 am
I have a lot of problem's.
I work with dn-hs5500 Audio 8
if you go to layer 1 one of 2 the decks stop playing.
Sound is like a hold record with a wrong middle hole.
With the new update is it not possible to play with my denon hs-5500.
Now I'm using virtual dj 6.02 normally I use 6.05 but I forgot to save dis version.
Is it possible to downgrade to 6.05
Thx
Dimi
Thx
Dimi
Posted Mon 08 Mar 10 @ 1:10 pm
Thank you vdj for the update. I use the mapper with the numark mixdeck and it works pretty well. I seem to enjoy the numark mixdeck w/time code and vdj 5.06 better. Platters touch sensitive jog wheels feel better. My gig laptops are still running 5.06/w windows xp. Havent gotten use to 6.05 or the new 6.07. Time code and mixdeck w/maya 44 sound card seem very stable for me. For smaller gigs I have two hercules mk2's. I always carry at least one hercules mk2 to every gig for back up. It just stays in the bag with the back up laptop.
Posted Mon 08 Mar 10 @ 1:23 pm
Yes can i get a link so i can get 6.05 6.07 is not working well for me
Posted Mon 08 Mar 10 @ 3:59 pm
Done
Posted Mon 08 Mar 10 @ 4:05 pm
you guys are the shizz!!!
Posted Mon 08 Mar 10 @ 7:19 pm
I found out that if I uninstalled vdj before I installed the 6.07 it would work great. I had just upgraded from 6.05 at first and had problems. So I think if you did a clean install, it might solve some issues that you may have. It worked for me.
Posted Mon 08 Mar 10 @ 7:37 pm
Thanks for letting me know about the updated version. I will play with it tonight. Thanks again whoever posted it....
Posted Mon 08 Mar 10 @ 7:52 pm
Something is definately broken in this version concerning the NS7 the pitch is all wobbly just playing a track you can hear the wow and flutter like an old turntable.
Posted Mon 08 Mar 10 @ 7:59 pm
