Is there a way to create multiple copy of this plugin and not have the default setting stored in plug_in.xml? What I'm trying to do is have a 3 versions of Loopout2.01 one that will loop out then stop and 2 others that will loop out then play with different beats. I want to be able to program my RMX buttons to use the same effects but with different settings. It seems like I can make a copy of it and give it another name but after restarting they both come up with the same setting.
Thanks for looking,
Eric
Thanks for looking,
Eric
Posted Tue 23 Feb 10 @ 4:35 am
