Forum: VirtualDJ Plugins
Topic: Loopout 2.01 help
Is there a way to create multiple copy of this plugin and not have the default setting stored in plug_in.xml? What I'm trying to do is have a 3 versions of Loopout2.01 one that will loop out then stop and 2 others that will loop out then play with different beats. I want to be able to program my RMX buttons to use the same effects but with different settings. It seems like I can make a copy of it and give it another name but after restarting they both come up with the same setting.
Thanks for looking,
Eric
Posted Tue 23 Feb 10 @ 4:35 am
