Forum: Old versions
Topic: DAC2 outerwheel outside jog wheel - Page: 2
The same with me.
Everything works fine with de DAC-2.
But I really miss the function of the outer wheel.......
It's a simple code i have to fill in, but I can't find it.
Can someone help me/us?
here the same.
I've the DAC-2 with VDJ 6 and the new mapper.
Can some find out what the command is to seek true the song with the outer wheel????????
I think you would help many people, including me!
I just upgraded to 6.0 and have the same problem with the Dac 2, no outer jog wheel or BPM or Time remaining on the display of the Dac. I I havn't been on the VDJ Site for several months and see that all the posts on this topic are from June. No updates since then. Does this mean nobody has been able to properly map the outer wheel on the Dac 2?
Correction on the dates of the posts. Just noticed the previous post was Aug. 9th. So this is still a problem. Anyone getting close yet?
downloaded dgruetter's Dac 2 mapper and when I hit the .exe file, goit a message saying "make sure Dac 2 is connected to USB port". It was so I hit ok. Then opened VDJ ver. 6 and it seems the mapper that came with ver. 6 is still there. No change as far as functinality. Do I have to somehow select or turn on dgruetter's Dac 2 mapper and if so how? I want to get BPM, Time remaining and outer jog wheel working and am hoping his mapper solves these problems(except for the outer jog wheel as it seems no one has solved that problem yet).
There shouldn't be an .exe in the download file. Just a Zipped .XML file. Just unzip it into \VirtualDJ\Mappers and replace the default mapper (which I believe is blank anyway). Then all you need to do is make sure you select "use serial devices" in the mappers section on the options screen. Then it should work.
Thanks, it's working better now. I can see the BPM's and elapsed time. Is there a way to see time remaining instead of elapsed time?
Try the readme
I think it explains how to change it.
Thanks. All set. Now if only someone can figure out the outer jog wheel and video transition bug, ver. 6 should be solid.
Yeah, I can live without the outer wheel but it would be nice to have full functionality of the dac-2.
yes....
thats what i need too
I'm also a registered user... whose VDJ6 sits in a folder... uninstalled... until somebody with the code-smarts I DON'T have gets the DAC2 jog wheels to work like it did in VDJ5 :( Soon, I hope... keep us posted !
HI this works in 6.0.4
map OUTERWHEEL to this action
param_smaller 0.01 ? seek -64 : param_smaller 0.08 ? seek -32 : param_smaller 0.15 ? seek -16 : param_smaller 0.22 ? seek -8 : param_smaller 0.29 ? seek -4 : param_smaller 0.36 ? seek -2 : param_smaller 0.43 ? seek -1 : param_smaller 0.52 ? seek 0 : param_smaller 0.58 ? seek +1 : param_smaller 0.65 ? seek +2 : param_smaller 0.72 ? seek +4 : param_smaller 0.80 ? seek +8 : param_smaller 0.87 ? seek +16 : param_smaller 0.94 ? seek +32 : param_smaller 1.1 ? seek +64 : nothing
Awesome job thanks lopez453!
Lopez thats brilliant mate, well done.
A new one for you, How can I get the 'Wheel' just to browse up and down track list, and not do anything during Play?
Many Thanks
Goochie.
You mean the OUTER WHEEL or the inner WHEEL ?
I assume he means the outer wheel.
dgruetter, you think you could send me/post the mapping XML for the DAC 2? It would be a great help...
Just check the plugin section to download it. I cannot email anyone the mapper sorry.
Please DO NOT ask our registered users to send you add-ons to which you are not currently entitled to.
You will need to purchase and register VirtualDJ Professional to be able to download mappers and other add-ons: https://virtualdj.com/buy/
