TearEmUp wrote :
Are you using the Victrola time codes?
chriso710 wrote :
Don't know what all the hype is about, still won't play my 78's :)
Great work guys, thank you.
Good come back Lol
Posted Sun 31 May 09 @ 7:50 pm
OK for some reason, the cue button has lost it's sensitivity with the new skin. With the old skin I was able to hit cue over and over and it would respond 99% of the time. Now it's like hit or miss. What gives? And what happened to the eq kill on the new skin. Love the look, not sure about the feel.
Posted Sun 31 May 09 @ 7:51 pm
Not having the cue button problem here ... CUE or HOT CUE
As for the eq kill ... double right click on the knobs ...
Posted Sun 31 May 09 @ 7:57 pm
Are you hitting it simultaneously? Seems like it misses every other time.
Posted Sun 31 May 09 @ 8:01 pm
Yes ... but I am not trying to click like a machine gun .. lol ... but I am clicking fast ...
Posted Sun 31 May 09 @ 8:03 pm
well i've gone and bit the bullit and bought version 6 goodbye pcdj vj
Posted Sun 31 May 09 @ 8:11 pm
Cue button is definitely not as responsive as it was with 5.2.1.
Got the right click for eq kill.
Also, what if i want to deactivate my controller while VDJ is playing? I was able to do so with 5.2.1. Is there another way?
You should be able to untick the controller in the mapper window dropdown to disable it.
Posted Sun 31 May 09 @ 8:13 pm
Thanks cstoll and SBDJ.
Just wondering about cue sensitivity. I like to use it as a stutter.
Posted Sun 31 May 09 @ 8:17 pm
why doesnt my vdj respond unless my HD4500 is conneted? if i press play, nothing happens
Posted Sun 31 May 09 @ 8:34 pm
Is HD4500 activated by mistake?
Posted Sun 31 May 09 @ 8:46 pm
tried restarting my computer and everything. i had the same problem in vdj5 after i unhook my controller i would have to click amd then unclick "built in output" and i would be fine.... now its just frozen.. the buttons on vdj light up, just dont respond
Posted Sun 31 May 09 @ 8:54 pm
@dat_boi_tj ... is this still the Mac Version ?? Please post those in the Mac Forums...
If it is the PC version ... do you disconnect it with VDJ open? And are you using the built-in soundcard of the 4500 as the soundcard? If so, then you need to change your sound card settings as you are no longer using what was previously set.
Posted Sun 31 May 09 @ 8:56 pm
i dont remember is VDJ was still open... but i already switched the sound card option...
Posted Sun 31 May 09 @ 9:03 pm
What did you switch the settings to?
Posted Sun 31 May 09 @ 9:06 pm
cstoll wrote :
1. - Why ? It converts the database by 'copying' the v5 file in order to add the Unicode support
2. Keyboard shortcuts from v5 are automatically converted at install
3. What do you want to know ? Go to the Config -> Mapper tab and select the DAC-3 then scroll through each item and read what is assigned to the buttons .. it should be pretty close to the labels on the DAC
JOSETHEDJ wrote :
WOW! Another great creation. Thanks for the update.
Need help with the following:
1) Importing 5.2 database
2) Importing keyboard Shortcuts or how to back them up if they need to be re-done
3) Using Dac 3 mapper capabilities.
I'll keep playing.
I'll keep playing.
Cstoll,
As always, thanks for your help.
I did not do an upgrade. I do have the the database and shortcuts backed up.
Should I just do an upgrade and let VDJ 6 update the database and shortcuts?
For my DAC 3 I use the mapper.. I got used to it. I just need to change the items then do a back-up.
Posted Sun 31 May 09 @ 9:38 pm
dOES ANY ONE KNOWS ID I CAN CONNECT THE NS7 TO VD6 YET?
AND HOW? I DONT SEE ANY WAY TO POSIBLY DO IT?
Posted Sun 31 May 09 @ 9:41 pm
Anyone else try the VCI-300?....we are not having much luck any info please post here:
https://virtualdj.com/forums/109662/Hardware_Technical_Support/VDJ6_and_Vestax_VCI-300_support.html
Posted Sun 31 May 09 @ 10:03 pm
built in output
Posted Sun 31 May 09 @ 10:26 pm
dat_boi_tj wrote :
built in output
Post your issues in the Mac forum ... NOT HERE ... the Mac is beta and it will confuse the people here talking about the PC version ...
Please keep them separate ...
Thank you....
Posted Sun 31 May 09 @ 10:51 pm
