just installed my rmx drivers ect.playing around but no sound comming from my laptop what am i doin wrong
Posted Sat 22 Nov 08 @ 12:42 pm
Nothing, once you plug in the controller it mutes the computer speakers. Once you plug the usb in the computer thinks its the new speaker setup. You would need external set of spreakers or mall computer speakers.
Posted Sat 22 Nov 08 @ 12:51 pm
Yes, when you install drivers for RMX, OS automatically sets it as default playback device. You should connect your speakers to RMX itself. If you still wanna use your original output, go to Control Panel>Sounds and select your laptop sound card.
Posted Sat 22 Nov 08 @ 1:01 pm
yes got it thanks just wanted to use my rmx for the first time.so is there a way to assign my buttons to my samples.also if i want to just go from my rmx to my amp which connections do i use
Posted Sat 22 Nov 08 @ 1:50 pm
I prefer the 1/4 inch connections, they are +4db louder than the RCA connections.
Posted Sat 22 Nov 08 @ 1:55 pm
thanks tear.so each side of the 1/4 inch does each side of my amp.how do i assign my samples to my buttons 1-6.also do i just use 3/4 for say and ipod for back up ect
Posted Sat 22 Nov 08 @ 2:18 pm
load the rmx skin and the rmx config plugin...should be able to assign functions.
Posted Sat 22 Nov 08 @ 6:13 pm
Isn't those outputs should be the same on the RMX? I just ask as I don't have it.
Posted Sat 22 Nov 08 @ 9:41 pm
djalf i think they era phono from the ipod.read the wiki but i like getting my info from people in the know with experience.
Posted Sun 23 Nov 08 @ 5:40 am
You say Terry has no experience? Strange, but I don't know what Ipod you are mentioning?
Posted Sun 23 Nov 08 @ 7:42 am
terry is correct, 1/4 out direct to amp from rmx, or rca out from rmx to external mixer...
Posted Sun 23 Nov 08 @ 7:47 am
thanks guys for your great help as usual.is there a mapper for rmx or is there a way to assign 1-6 buttons
Posted Sun 23 Nov 08 @ 8:08 am
There is no mapper yet, but you have configurator for 6 buttons here:
https://virtualdj.com/addons/4430/Rmx_Buttons_Configurator.html
Posted Sun 23 Nov 08 @ 8:19 am
thanks alf.love this forum and my producy.all you newbies out there get pro edition and ask what you want here a lot of helpfull people whos help is invaluable
Posted Sun 23 Nov 08 @ 8:34 am
