I have an RMX controller but I need more buttons to control effects better. Is there a MIDI controller that I can use to controller sound effects and videos effects and Sampler. I just do want to be clicking around the software with the mouse. I've used the keyboard and assigned short cuts but when i comes to adjusting the flanger for example it's not that easy.
Will something like this work with VDJ and an RMX controller together?
http://keyboards-midi.musiciansfriend.com/product/Behringer-BCR2000-BControl-Rotary?sku=701762
or
http://keyboards-midi.musiciansfriend.com/product/Novation-ReMOTE-Zero-SL?sku=701054
Thanks for looking,
Eric
or
Thanks for looking,
Eric
Posted Fri 21 Nov 08 @ 7:41 pm
A popular one is the trigger finger: http://www.m-audio.com/products/en_us/TriggerFinger.html
Posted Fri 21 Nov 08 @ 8:48 pm
prolly could have just bought the xponent instead of the rmx. . . :>
im not exactly sure but i believe the xponent has about thirty percent more buttons to program for effects, etc. ?
Posted Sat 22 Nov 08 @ 12:49 am
p.s.
the trigger finger looks sick.
and now back to mixing.
Posted Sat 22 Nov 08 @ 12:51 am
This is nice but how would a touch sensitive pads be really beneficial with virtual dj ,when you usually just turn things on and off.
Is there a plug in that we can assign drum sounds?
Posted Sun 23 Nov 08 @ 12:00 am
No, but you can use them as normal pads instead of velocity sensitive I would imagine, so you could use them to trigger functions, or control the clipbank etc...
Posted Sun 23 Nov 08 @ 8:12 am
I use my trigger finger to jump to cue points. I assign the cue points to the pads and I'll tap on the pad instead of the keyboard. You can set it to continue play from the cue point on or to release when you take your finger off.
Posted Tue 09 Dec 08 @ 11:29 pm
I use:
Numark Total Control
M-Audio Trigger Finger
M-Audio X-session Pro
and
A single Pioneer CDJ-800mk2
Together I can do everything I want or need to do with the music and the lighting.
and
Posted Wed 10 Dec 08 @ 7:13 am
nothing cheaper than the trigger ? that costs a lot for an additional controller :p
Posted Fri 12 Dec 08 @ 12:49 am
