Topic: adv help!
I recently was trying some skins out and i try one out and about 5 mins of using decided i dint like it but i looked around for the config button and it was no where to be found so my ? is is thier a key short cut to open the config menu up? and if not how about manually adding a different skin manually? any help be awesome!
Posted Fri 21 Nov 08 @ 5:07 am
skins from this site are only available to licensed users, get them from anywhere else and you do so at your own peril i'm afraid. the only advice i can give is to delete the file before opening up vdj.
