hi, everytime i start up vdj, it saids loading database, then 3 seconds later my computer totally freeze, i cant move my mouse and i have to restart my computer, wats the problem?
Posted Tue 18 Nov 08 @ 11:32 am
plz help this is urgent
Posted Tue 18 Nov 08 @ 12:30 pm
Aloha, I've experienced identical problem where VDJ would completely freeze 30 to 40 minutes show.. The only way to clear freeze is to reboot laptop (turn off/turn back on) not a healthy way to reboot machine. I never did get an answer or find one on forum.
I was surprised it happen again yesterday after 3 shows with no problem whatsoever, I thought skin was causing freeze.. The only difference I've noticed yesterday, turned on keyboard light, which I haven't used in a while since last freeze. Has anyone esle experience the same problem.
Thanks and hopefully VDJ can resolve problem,
Suga
Suga
Posted Thu 20 Nov 08 @ 12:41 pm
Maybe your database file it's corrupted.
I think you are using VDJ V3.4.
You can use the "xml database validator".
Download HERE.
Good luck.
Download HERE.
Good luck.
Posted Thu 20 Nov 08 @ 1:57 pm
Aloha Xonor,
I'm using V5.2..
Thanks,
Suga
I'm using V5.2..
Thanks,
Suga
Posted Sat 22 Nov 08 @ 2:09 pm
djsugaray wrote :
Aloha Xonor,
I'm using V5.2..
Thanks,
Suga
I'm using V5.2..
Thanks,
Suga
I was talking to RCdude, he got V3.4
Your problem djsugaray, it's diferent.
You can start VDJ, but RCdude not.
Your prob maybe it's by a system performance, heat or similar.
Posted Sun 23 Nov 08 @ 10:26 am
