is it better to use the hercules mrx sound card when useing the amps and large speackers or the laptop sound card. the mic on the mrx only seem to work with mrx sound card picked. i only have two channel input for the amps. will both decks work just useing 1-2 out put from the mrx. i know this stuff get old for u yal. i think we all know that newbee are a pain in the azz. but sometimes u just have to ask. that book
learning heart my head.
Posted Fri 14 Nov 08 @ 10:47 am
Yes, you can only use the 1-2 outputs to plug on your mixer or speakers.
If you are using a Professional Audio equipment, you better use the JACK conectors to gain 4db.
Good luck.
Good luck.
Posted Fri 14 Nov 08 @ 8:14 pm
