Topic: more problems
hello i was just wondering how i can make my mic work on broadcasting to a radio, i plug the mic in my consol at the front nd have broadcast options set to master nd mic but there is no mic sound on the radio can anyone help.?
Posted Thu 13 Nov 08 @ 5:01 pm
Do you have the mic selected on your PCs system as the audio and voice recording device? If not then Control Panel>Sounds and Audio Devices>Audio +Voice. Test hardware, shut down VDJ. Reboot, open VDJ and see if it works now.
ive selected on virtual dj master and mic on record and broad cast i plug the mic in the front of the mixer port even though its the talkover option and doesnt work and ive even tried setting mic to primary driver / the computer and plugged it into the back of the computer rather then the mixer and it still doesnt work ?
