If anybody is considering buying a vci 100 and has doubts about it then check this video out.
Old School Hip-Hop Part 1 on the Vestax VCI 100
http://www.youtube.com/watch?v=h3_fji9Nxjo&feature=email
Posted Wed 12 Nov 08 @ 8:22 am
DJBIGMARK wrote :
If anybody is considering buying a vci 100 and has doubts about then check this video out.
so is vestax VCI work on VDJ???
Posted Wed 12 Nov 08 @ 8:23 am
Yes it works perfectly with vdj , no problems at all. I am using itunes to organize my music and I have a numark djio card. I have used it live at pareties and a bar, so far no issues. I was going to get the vci 300 but don't need to spend the extra money.
Posted Wed 12 Nov 08 @ 8:37 am
oh yea i forgot that the Vistax didnt come with the Sound card....hmm..sounds good..i might sell my Total control to buy the Vistax VCI-100..
Posted Wed 12 Nov 08 @ 9:25 am
hey big mark just picked one up...there is a slight lag when i skratch...how did u remedy this?
it spot on mixing....how did u set up buttons?
Posted Sun 16 Nov 08 @ 3:58 am
Hey big mark that was a sweet mix, what mapping are you using?
I'm sure you can't be doing that with the native mapping as its pretty poor?
The vinyl mode is just nudge and doesn't utilise the touch sensitivity at all and the non vinyl mode is just plain useless.
Could you send me the xml file you have?
I wish you could map the lights in general midi mode.
Posted Sun 16 Nov 08 @ 4:56 am
